Construct Matrix P & Find Trace/Eigenvalues - Can Anyone Help?
abiadams
Am really lost on this one:
Suppose X is a full rank nxp matrix. Construct the matrix:
P = I - X((X'X)^-1)X'
Where X' is the transpose of X.
I then have to find the trace and eigenvalues of P.
Can anyone help?!
do you know that for invertible matricies A,B that
(AB)^{-1} = B^{-1} A^{-1}
easy to see this, say C is the inverse of (AB), then
(AB)C = ABC = I
A^{-1}ABC = BC = A^{-1}
B^{-1}BC = C = B^{-1}A^{-1}
lanedance's comment is true, but since your matrix need not be square it doesn't help. You can't simplify
<br /> P = I - X(X&#039;X)^{-1} X&#039;<br />
any more than it already is.
This is the type of problem seen during a matrix introduction to multiple regression (although it may be in a different setting for your problem).
Hint: You can show that P^2 = P (P is actually a projection matrix).
1) What is its dimension?
2) If you know the rank of X you can find the rank of P
Those hints will (should, may) give you an idea of an attack to find the quantities you need.
ok, yeah - misread that sorry
along with statdads comments, the property of the trace being the sum of the eigenvalues
tr(A) = \sum_i a_ii = \sum_i \lambda_i
and
tr(A^k) = \sum_i \lambda_i^k
could help
