zemzi
- 2
- 0
I made a code in assembly 8086. I load matrix (array) in memory with dimension 3x3. but this code works just for this dimension of matrix 3x3. Could someone give me an idea how could i make it to work with dimension m x n? the array is loaded in memory and at the end just print the result, another array. thanks
; multi-segment executable file template.
data segment
matrix db 1, 2, 3, 4, 5, 6, 7, 8, 9 ; load matrix in memory
ends
stack segment
dw 128 dup(0)
ends
code segment
start:
; set segment registers:
mov ax, data
mov ds, ax
mov es, ax
mov bx, matrix ; move matrix to offset bx
mov ch, 3
mov cl, 0
COLUMNAHEAD:
mov dl, [bx] ; get the first element of matrix in dl
add dl, 30h ; add to show number
mov ah, 02h
int 21h ; print first number
inc cl
cmp cl, ch ; compare if the counter is at the end of column
jge ROWAHEAD ; if greater go to row
add bx, 3 ; if not inc offset for 3
jmp COLUMNAHEAD
ROWAHEAD:
inc cl ; 1 element of roe
inc bx ; inc offset for one place
mov dl, [bx] ; get the number in dl
add dl, 30h ; convert to number
mov ah, 02h
int 21h ; print the number
cmp cl, 5
je COLUMNAHEAD
jne ROWAHEAD
COLUMNBACK:
inc cl
sub bx, 3
mov dl, [bx]
add dl, 30h
mov ah, 02h
int 21h
cmp cl, 7
jne COLUMNBACK
je ROWBACK
ROWBACK:
dec bx
mov dl, [bx]
add dl, 30h
mov ah, 02h
int 21h
JMP MIDDLE
MIDDLE:
add bx, 3
mov dl, [bx]
add dl, 30h
mov ah, 02h
int 21h
JMP END
END:
this is the code i wrote. it works for the matrix
1, 2, 3,
4, 5, 6,
7, 8, 9 and print 1, 4, 7, 8, 9, 6, 3, 2, 5
Matrix given in memory to print the spiral in opposite direction from clockwise (left column down the right lower range, right up column, a series of upper left, etc. until you get to the environment). This works just for dimension 3x3. this should works for mxn dimension. but i don't know how, any suggestion?
data segment
ends
stack segment
dw 128 dup(0)
ends
code segment
start:
mov ax, data
mov ds, ax
mov es, ax
mov ch, 3
mov cl, 0
COLUMNAHEAD:
mov ah, 02h
inc cl
jmp COLUMNAHEAD
ROWAHEAD:
mov ah, 02h
cmp cl, 5
je COLUMNAHEAD
jne ROWAHEAD
COLUMNBACK:
inc cl
sub bx, 3
mov dl, [bx]
add dl, 30h
mov ah, 02h
int 21h
cmp cl, 7
jne COLUMNBACK
je ROWBACK
ROWBACK:
dec bx
mov dl, [bx]
add dl, 30h
mov ah, 02h
int 21h
JMP MIDDLE
MIDDLE:
add bx, 3
mov dl, [bx]
add dl, 30h
mov ah, 02h
int 21h
JMP END
END:
1, 2, 3,
4, 5, 6,
