Matrix Proofs Homework: Q1 & Q2
  • Thread starter Thread starter colt
    Matrix Proofs
The discussion revolves around two questions related to matrix properties and proofs involving invertible matrices. The first question asks to show that if A and B are invertible square matrices, then the inverse of their sum can be expressed in terms of their individual inverses. The second question involves the determinant of a transformed matrix under an invertible matrix.
  • Mixed
  • Participants explore the manipulation of matrix expressions and properties of determinants. There are attempts to simplify expressions and verify identities related to matrix inverses. Questions arise about the assumptions regarding the invertibility of matrices involved and the properties of determinants.
Participants are actively engaging with the problems, providing insights and questioning assumptions. Some guidance has been offered regarding the properties of determinants and the manipulation of matrix expressions, but no consensus has been reached on the solutions.
There is an ongoing discussion about the assumptions needed for the invertibility of the sum of matrices A and B, as well as the properties of determinants that may apply to the second question.
colt
First Question: Be A and B square matrix. Show that if A and B are invertible matrix, then: (A + B)^(-1) = A^(-1) * [I + B*A^(-1)]^(-1)
First Queston: (A+B)^(-1) = [A^(-1) + A^(-1)*B*A^(-1)]^(-1) (I distributed the a^(-1) outside the []). Then I don't know what else I can do
Second Question: Be A and P matrix of nxn dimension with P being invertible. So det (P^(-1)*A*P) = det(A)
I would like to transform the (P^(-1)*A*P) into (I*A), but since matrix multiplication ain't commutative, I don't know how to get there
You can verify this by showing that
$$(A+B)(A^{-1}[I + BA^{-1}]^{-1}) = I$$
What properties of determinants do you know about?
I was only able to develop it until here:
[itex]A(A^{-1}[I + BA^{-1}]^{-1}) + B(A^{-1}[I + BA^{-1}]^{-1}) =[/itex]
[itex]AA^{-1}[I + BA^{-1}]^{-}) + BA^{-1}[I + BA^{-1}]^{-1} =[/itex]
[itex]I[I + BA^{-1}]^{-1} + BA^{-1}[I + BA^{-1}]^{-1} =[/itex]
[itex][I + BA^{-1}]^{-1} + B[A^{-1} + A^{-1}BA^{-1}]^{-1} =[/itex]
I know that de determinant of A^(-1) = 1/ det A, that det A = det A transpose, that the det A with a constant K that multiplies one of its lines is equal to K that multiplies det A and so that if this constant multiplies all lines. then det A = K^n * det A
I think the problem is asking you to assume that the wrong things are invertible. A and B invertible doesn't show A+B is invertible. You need to assume that everything is invertible. Then for the first use that C^(-1)D^(-1)=(DC)^(-1). Figure out what to put D and C equal to.
Now try using the distributive property.
Another important property: ##\det(AB) = \det(A)\det(B)##. Do you know this one? If so, the second problem should be easy.
How? The identity is irrelevant, so only the [itex]a^{-1}[/itex] is left, and I already distributed it without seeing any meaningful result
Another important property:[itex]det(AB)=det(A)det(B).[/itex] Do you know this one? If so, the second problem should be easy.
Ah yes, had forgotten this one.
Didn't really understand. Can you try to explain it once more?
What I mean is take the inverse of both sides of (A + B)^(-1) = A^(-1) * [I + B*A^(-1)]^(-1). What you first did, distributing the A^(-1) inside of the [] is quite wrong. There's a ^(-1) on the bracket.
jbunniii said:
now try using the distributive property.
colt said:
how? The identity is irrelevant, so only the [itex]a^{-1}[/itex] is left, and i already distributed it without seeing any meaningful result
Both terms have a common factor on the right, namely ##(I + BA^{-1})^{-1}##:
$$I(I+BA^{-1})^{-1} + BA^{-1}(I+BA^{-1})^{-1}$$
So factor out that common term and see what you get.
Yes, I have to admit that I was suspicious about this distributive. Thanks for pointing it out.
Both terms have a common factor on the right, namely (I+BA−1)−1:
[itex]I(I+BA−1)−1+BA−1(I+BA−1)−1[/itex]
I see it now. Thanks
  • · Replies 18 ·
