How do diodes handle high current spikes when charging capacitive loads?
Diodes experience high current spikes when charging capacitive loads due to the low impedance of the source, which can lead to currents significantly exceeding their peak pulse ratings. While many diodes have low peak pulse current specifications, they can handle surge currents effectively, as seen in applications like car batteries. The surge current rating (Ifsm) indicates the diode's ability to withstand brief spikes, but does not imply it can handle such currents repeatedly. The diode selection should align with the specific circuit requirements, considering factors like average current, surge capability, and recovery time. For larger capacitive loads, additional measures such as series resistance or soft-start circuits may be necessary to manage inrush currents.
DragonPetter
If I consider a simple example of charging a capacitive load with a low impedance source, and charge the capacitor through a diode, I will have a very high current spike through the diode while the capacitor charges to the supplied voltage.
When I look for diodes and see their peak pulse current, most of them are quite small compared to the "theoretical" infinite current you would have into a capacitor to charge it.
Say the ESR of a capacitor is 100 mOhms, and you charge it with a 20V source through the diode, the current spike in the diode will be about (20-.7)/.1 = 199 amps, and I have not found a normal diode that has this spec.
Yet I have seen, for example, a car battery with a diode after its positive terminal, to protect a reverse voltage connection, and then feed into a capacitive load (ceramic capacitors in front of a SMPS) and these diodes are fine.
Why do these diodes have small peak pulse currents, but can handle surge currents?
In theory most power supplies will have an extremely high in-rush current to the filter capacitor. Rectifier diodes generally have a much higher Ifsm or "Surge Rating" than Iav or "Average Current Rating". For instance: http://www.diodes.com/datasheets/ds28010.pdf has an Iav of 10A, but an Ifsm of 600A. But we need to be clear here, this does NOT mean the diode can handle a 600A repetitive current, it simply means that the device can handle a brief spike of 600A (and this figure is a bit misleading, the actual maximum current is limited more by the junction temperature Tj).
A lot depends on what the diode is designed to do. In your example of a car battery with a protective diode, the diode does not need to be "fast" or have a "low forward voltage drop", it needs to have a high surge current and a sufficiently high Average Current to supply the SMPS. In the case of the output rectifier for an SMPS, other characteristics like reverse recovery time and low forward drop may be far more critical to efficient operation.
The key is selecting the diode that best fits the needs of your circuit.
Fish
Thank you that is very helpful. I haven't seen a surge rating, but I wasn't looking for it either. I'll check some datasheets again.
In the situation you describe, with ceramic capacitors of probably quite low values, the inrush current will flow for only a brief period. For instance, with R = 0.1 ohm and C = 10 micro farads we get a time constant RC = 1 microsecond. This is much shorter than the 8.3ms often quoted in a diode Ifsm rating.
The situation is of course different where very large capacitances are concerned (big electrolytics or even "supercapacitors"). In such cases, the inrush lasts far longer and so has to be treated more seriously. A deliberate series element or even an active "soft-start" arrangement may be necessary to keep the current to a tolerable level.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
