Max efficiency (thermodynamics)
The discussion centers on the efficiency of a heat engine and the role of heat extraction between points 3 and 4 on the p-v diagram. The efficiency formula, η = 1 - (Qc/Qh), highlights the losses incurred when heat is not adequately managed. Achieving 100% efficiency is theoretically possible if cooling is eliminated, assuming no friction. The conversation also explores the challenges of implementing isobaric processes in practical applications, questioning how to compress the working fluid without altering pressure or temperature. The complexities of real-world applications of isobaric processes remain a point of inquiry.
pinsky
I'm observing the circular process of a heat engine. It's p-v diagram is
So between points 3 and 4 the heat is extracted. That causes losses since the efficiency if given by
\eta =1- \frac {Q_c} {Q_h}
Where Qh is the heat the heat source has given and Q_c the amount of heat that the "cold" container took.
If we don't cool down the engine in during the process between 3 and 4, the efficiency would grow to 100% (if friction is not consigered).
The process would then look like the picture below, and 3 and 1 we would do an isobaric contraction.
I've encountered isobaric processes through my studies, but only as a theoretical concept. What are the reasons why it couldn't be used here?
Science news on Phys.org
How can you do compress the working fluid without changing its pressure or temperature?
I don't know, how do you get an isobaric process ever? :)
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
