What is the significance of Max Q in rocket launches and disasters?
Max Q, or maximum dynamic pressure, is a critical phase during rocket launches where the vehicle experiences peak aerodynamic stress. For the Space Shuttle, this pressure reached 720 pounds per square foot, significantly lower than typical car tire pressure, yet it represents a substantial force on the shuttle's structure. The discussion raises concerns about how this pressure impacts rocket design, particularly in relation to vibrations and structural integrity during launch. Comparisons are made to aircraft, suggesting that their maximum dynamic pressures are generally lower than those of rockets. Understanding Max Q is essential for ensuring the safety and performance of launch vehicles.
Devils
So I was reading about the challenger disaster and came across this report:
http://history.nasa.gov/rogersrep/v1ch3.htm
Both the Shuttle main engines and the solid rockets operated at reduced thrust approaching and passing through the area of maximum dynamic pressure of 720 pounds per square foot.
I listed to rocket launches & they all seem to mention MaxQ but have never seen a value. From the report, 720 pounds per square foot = exactly 5psi. A typical car tyre is 30psi, so the maximum pressure on the space shuttle is about 1/6 of that of a car tyre.
That seems low to me so why mention it at all? The recent SpaceX was near Max Q so was that part of the problem, is was vibration the problem? What is Max Q for an airplane?
I don't know what I'm talking about, but just from a quick glance, a tire is small and the pressure is distributed nice and evenly, over a smooth profile. And if you make the tire 2-5 times stronger than it needs to be, well no big deal. On a space shuttle with an (educated guess) frontal area of 80000 in^2, that 5psi adds up to 400,000 lbs of extra force, squeezing it lengthwise along uneven paths and who knows what, designed to be juuuust strong enough, in a complex machine with a small nuke's worth of explosives. That's definitely something that should be accounted for in the rocket's design.
I don't know what the maxQ of an aircraft is but pretty sure the VNE (Velocity Never Exceed) will be lower for a plane than a rocket perhaps by a factor of five?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
