Maximum Angle of Incline for four wheel drive
The discussion centers on determining the maximum angle of incline for a four-wheel drive vehicle, with estimates ranging between 11 and 12 degrees. Participants question the coefficient of friction, debating whether it is kinetic or static, and how it affects the vehicle's ability to ascend while slipping. The relationship between incline angle and the center of mass is emphasized as crucial for understanding vehicle dynamics. There is skepticism about the assumed coefficient of friction, with comments suggesting that a value of 0.2 seems unusually low for a typical incline. Overall, the conversation highlights the need for clarity on the equations and methods used to calculate the incline's impact on vehicle performance.
Laura2988
I am looking to find the maximum Angle of inclination that a vehicle can drive up. The vehicle has four wheels each with a motor attached
Mass of vehicle = 6075kg
gravity =9.81m/s^2
Coefficient of friction=0.2
Motor torque (total)=9000Nm
Wheel radius = 0.4m
How do you calculate this?
I think it will be between 11 and 12 degrees but don't know how to re-arrange the equation or if I was even using the correct method
Is 0.2 the coefficient of kinetic or static friction? I assume that the vehicle goes uphill with the wheels spinning and slipping at the same time. The threshold condition is that the uphill force of kinetic friction balances the downhill component of the weight. Then the vehicle will move uphill at constant velocity,
Hello Laura, ##\qquad## :welcome: ##\qquad## !
Curious what it is you base your guess on ?
Read the guidelines and try to think of relationshiips between incline angle and position of center of mass.
Make a a sketch.
12 degrees is nothing for 4WD.
[edit] I missed the 0.2 -- did they lube the incline with oil or soap ?
What equation?
What method?
Likes BvU
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
