Is Maxwell's Demon Still an Unsolved Mystery?
In summary, Maxwell's zombies are unsolved problems in thermodynamics that involve the violation of the second law of thermodynamics.
I think the John Earman and John D. Norton argument pretty much ends the discussion. What they are saying is that the allowing the demon to violate the second law of thermodynamics boils down to a violation of the second law of thermodynamics - thus circular reasoning.
But it brings you back to the point of what drives the second law to begin with - just statistics. A violation of the second law of thermodynamics isn't impossible, just unlikely. If Maxwell's demon opened the door and a hot molecule just happened to cross from the cold side to the hot side, he could declare a win - based only on luck.
We live in a special case universe where there is ever increasing entropy and thus a direction to time - owing only to the fact that we started with a very low entropy condition just 14 billion years ago. If the universe ever settles into a warm death, there will be no increase in entropy, no second law, no direction to time, and no remaining evidence of an original Big Bang.
Likes rootone
rootone said:
https://en.wikipedia.org/wiki/Maxwell's_demon,
Is this solved, or any new ideas about it?
And to quote .Scott's post "If Maxwell's demon opened the door..." always a first action needed.
The thought I use is... An air compressor installed inside an air tank which is designed to operate as an air motor(turning the compressor inside), air being drawn in through the axle tube into the compressor and discharged into the tank, after a period of time the tank is under pressure and hot, the hot air is expanded through the tanks motor function and at zero pressure and lower than intake temperature, the air moves back into the surroundings.
The compressor is equal to the demon, it should boil down to a time, temperature ratio of work performed.
What is considered useful will determine if it has value IMO.
Likes rootone
Are Maxwell's Zombies on-topic in this thread? They are all unsolved, says Wikipedia.
https://en.wikipedia.org/wiki/Maxwell%27s_Zombie
Likes rootone
1. What is Maxwell's Demon?
Maxwell's Demon is a thought experiment proposed by physicist James Clerk Maxwell in 1867. It involves a hypothetical creature or device that has the ability to sort particles based on their energy levels, resulting in a decrease in entropy and a violation of the second law of thermodynamics.
2. Is Maxwell's Demon a solved problem?
There is no definitive answer to this question. While some scientists argue that the demon's actions can be explained by quantum mechanics and information theory, others believe that it is still an unsolved problem due to the impossibility of constructing such a device in reality.
3. How does Maxwell's Demon work?
The demon is assumed to have the ability to observe individual particles and open and close a door between two chambers based on their energy levels. This would result in the hot chamber becoming hotter and the cold chamber becoming colder, without any work being done, thus violating the second law of thermodynamics.
4. Why is Maxwell's Demon important in science?
Maxwell's Demon highlights the fundamental concepts of thermodynamics and the second law. It also raises questions about determinism, information theory, and the role of observation and measurement in physical systems.
5. Is there any experimental evidence for Maxwell's Demon?
At this time, there is no experimental evidence for the existence of Maxwell's Demon. However, some experiments have been conducted using microscopic systems that demonstrate similar effects, although they do not violate the second law of thermodynamics.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
