B3NR4Y
- 8
We are using Gaussian units. To begin, the vector Hk is the magnetic field, which relates to a second rank antisymmetric tensor, Fij.
a.) Prove
F_{ij} = \frac{\partial A_{j}}{\partial x_{ i }} - \frac{\partial A_{ i }}{\partial x_{j}} = \partial_{ i } A_{j} - \partial_{j} A_{ i }
where \nabla \times \vec{A} = \vec{H}
I'm only posting this first part because I feel like once I get it everything will roll out and I'll be able to answer it all.F_{ij} = \frac{\partial A_{j}}{\partial x_{ i }} - \frac{\partial A_{ i }}{\partial x_{j}} = \partial_{ i } A_{j} - \partial_{j} A_{ i }
In the last problem, we proved that H_{k} = \frac{1}{2} \epsilon_{ijk} F_{ij} \iff F_{ij} = \epsilon_{ijk} H_{k}
The last problem says that the tensor Fij can be written as the following matrix:
<br /> \left(\begin{array}{ccc}<br /> 0 & H_{z} & -H_{y} \\<br /> -H_{z} & 0 & H_{x} \\<br /> H_y & -H_x & 0 \end{array}\right) and the hint says that
(curl \, \vec{A})_{i} = \epsilon_{ijk} \partial_{j} A_{k} = H_{i} So, F_{12} = \partial_{1} A_2 - \partial_2 A_1. Do I just et the partials from the definition of the curl of A being H?
