May I suggest an experiment concerning negative energy?
In summary, the conversation discusses the idea of the Cashmeir effect being potentially due to negative energy and the suggestion of an experiment involving pockets to test this theory. The obstacles and challenges of performing this experiment are also discussed, along with the concept of negative energy and its relationship to mass. The conversation also mentions the Heisenberg uncertainty principle and its potential implications in this experiment, as well as a related article on separating positive and negative energy.
Negeng
38
Sometimes to understand things I need to come up with ideas and have them shot down.
This is what I am doing here.
I have been informed that the Cashmeir effect may not be due to negative energy so I have an idea for an additional experiment. Suppose we were to make a "box" with little "Pockets" and these "pockets" simulate the cashmeir effect by having the walls of the pockets be a very small distence from each other. If the cashmeir effect is indeed due to negative energy we would expect the box to weigh less than the materials that make it up, because the negative energy in the pockets would have negative mass. On the other hand I would assume this apparent decrease in mass would be very small, on par with weighing a photon. Futhermore gravity would most likely pull on the negative energy like it does postive energy so weighing the box would not be a simple matter of just putting it on a super acurate scale.
I would love to hear all kinds of comments on this possible experiment.
Negeng said:
On the other hand I would assume this apparent decrease in mass would be very small ...
Yes, that would be the main obstacle to perform the measurement.
First I guess you had better define what you mean by "negative energy". It is not at all clear to me why the Casimir effect (note spelling) should result in any mass decrease at all, even a very small one. Basically, whatever the interpretation, the Casimir effect is just a correction of the zero-point energy, based on what we would expect it to be in the absence of the effect.
If you put two methane molecules close together, and you don't know about, or neglect to consider van der Waals interaction, then you will be surprised when you find their zero-point energy is lower than you were expecting it to be. The Casimir effect is no different.
[EDIT] I should say that there will be an INCREDIBLY tiny mass change due to the extra binding energy in the system. It was so small that I didn't even notice it in my analysis ... perhaps the OP would like to calculate the size of the mass change?
I know the amount of negative energy within my suggested pockets would be small (if it's even there at all), but how small exactly? Is there an equation that would predict the amount of negative energy for any given dimensions in the pockets?
To my understanding mass and energy are interchangable so one could have say 1 killogram of energy. Therefore if my understanding of negative energy is correct then you could have
-1 killogram of negative energy and a negative amount of mass could exist within the two plates that creates the Casimir effect. Please correct me if I have misunderstood something.
I'm not really clear on the geometry of the pockets and box, but that's not important. The Casimir effect depends on the exclusion/displacement of non-resonant (posited) vacuum energies, not on their disappearance. Those displaced components will appear elsewhere in the box, presumably inside the material walls forming the excluding pockets.
For an analogy, we can make box containing some cellular substance, such as an aerogel and coat the inside of the cells with a 'getter' such as cesium. The cesium sucks up all the oxygen and leaves the nitrogen and argon, but the whole box weighs the same.
Is there any chance the Heisenberg uncertainty principle would allow the diplaced components to be outside the box?
Yes, but it would allow all components of the (conjectured) vacuum energy of both a pocketed and unpocketed box of identical mass to be outside the box anyway. IMO. At this point we need an expert to comment more precisely.
Well in the mean time I will draw people's attention to this article, http://xxx.lanl.gov/abs/gr-qc/9901074
It decribes an attempt to seprate positive energy from negative energy. The authors claim it can be done, but there are strong restrictions. Most notably any pulse of negative energy must be close to a pulse of postitive energy or the postive pulse must be much larger the the negative pulse. I leave it to you and others for futher interpertation.
That isn't quite what I see in the abstract. The bigger the positive and negative pulse, the closer they must be in time. Their earlier paper, they say, finds an asymmetry: the greater the separation (in time? that's what the previous context would suggest.), the greater the positive pulse than the negative one.
Yes...that's what I meant.
Well .. that is a theory paper, so I wouldn't characterize it as an "attempt to separate positive energy from negative energy", but rather as an attempt to prove that it can be done in principle. I am not sure if experimentalists even know how to generate such a "double-pulse" of positive/negative energy. I thought they were just types of vacuum fluctuations ...
I don't think realizing the theory in an experiment would help in the design of the Casimir box in any event. It would certainly involve measuring events in a small volume of space (and time). Your box would be large static thing which probably would not need any pulses measured or generated with respect to it. We would be measuring for bulk mass deviations.
I don't think the general idea of quntam interest and the Casimir box (I love that term by the way)need always be seprate. If quntam interest is indeed true then it means there could be some method of moving the displaced postive energy outside of the box while keeping the conjectured negative energy in it; the catch is we would not be able to do it for very long especially since we would need to isolate enouph of the casimir force to measure it's mass.
On the other hand if the double pulse experiment were conducted it would defeat the purpose of the casimir box; we only need one experiment that isolates the suposed negative energy after all.
So you just want the negative energy thing tested for reality, the Casimir box isn't necessary. Probably a lot of people would like to see that, but as SpectraCat suggests, it might be hard to test according to the paper.
negative energy can't be possible. Latest physics says, Matter is mass and wave. All frame set up such a way, combination of both can never be negative together in a close system.
If some one predicting negative energy , it means some problem with his theory model or defining the limitations of theory. If theory is not using first principle, a lot of mistakes always there.
I've been informed that there is no consesus on the matter and for that matter there has been no experiment that proves or disproves the existence of negative energy.
1. What is negative energy?
Negative energy is a theoretical concept in physics that refers to the potential energy of a system being less than zero. It is often associated with concepts such as anti-gravity and the possibility of faster-than-light travel.
2. Can negative energy be created or harnessed?
Currently, there is no known way to create or harness negative energy. It is purely a theoretical concept and has not been observed or proven to exist in the physical world.
3. How do scientists study negative energy?
Scientists study negative energy through mathematical models and theoretical calculations. It is also a topic of research in areas such as quantum mechanics and cosmology.
4. What are some potential uses of negative energy?
There is currently no practical or proven use for negative energy. However, some theories suggest that it could be used to create wormholes for faster-than-light travel or to manipulate the curvature of space-time.
5. Is there any evidence for the existence of negative energy?
There is currently no direct evidence for the existence of negative energy. However, some phenomena, such as the accelerating expansion of the universe, have been theorized to be caused by negative energy. Further research and experimentation are needed to confirm its existence.
  • Quantum Physics
  • Quantum Physics
