Magnetism and Conducting Loops: Which Description is Correct?
  • Thread starter Thread starter KLscilevothma
    Magnetism
The discussion centers around a physics exam question regarding the behavior of a conducting loop in the presence of a bar magnet. The key points include the interaction of the loop with the magnetic field, where the loop experiences forces due to induced currents. The correct answer options are debated, particularly focusing on whether the loop is attracted or repelled and how its area changes. It is clarified that if the loop is flexible, the opposing currents in different segments cause repulsion, leading to an increase in the loop's area as it expands. The confusion arises around the concept of area versus volume expansion, with participants emphasizing that the loop's sides will stretch, thereby increasing the area, rather than merely expanding in volume.
KLscilevothma
This question appeared in the physics exam yesterday and I'm not sure what is the correct answer.
The figure shows a light and flexible conducting loop C freely hung on a smooth horizontal rail. A bar magnet PQ approaches the loop from the right. Which of the following descriptions about this process is correct ?
A. if P is an N-pole, the loop will be repelled ot the left and its area will increase slightly.
B. If P is an N-ple, the loop will be attracted to the right and its area will decrease slightly.
C. No matter whether P is an N-pole or a S-pole, the loop will be repelled to the left and its are will decrease slightly.
D. No matter whether P is an N-pole or a S-pole, the loop will be repelled to the left and its area will increase slightly.
I think the correct answer is either C or D but I don't know why the change in area of the loop is involved in this process.
Edit:typo
Think of two current-carrying wires side by side. They exert forces on each other, depending on the orientation of the currents. Now consider that loop with its induced current. Segments of the loop on opposite sides carry current in opposite directions, so they repel each other. So the flexible loop expands.
Um.. but what I can imagine is volume expansion of the loop but the area doesn't change, just like the case when 2 current carring wires are put side by side, they repel each other if the currect direction is opposite. Am I missing something here ?
I don't know what you mean by "volume" expansion of the loop. If two current-carrying wires repel, they will spread apart if free to do so. For the loop, opposite sides repel. Since the loop is flexible, the sides will stretch open, increasing the loop area.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
