Meassuring Resistance under water?
  • Thread starter Thread starter HappMatt
    Resistance Water
4 replies · 4K views
HappMatt
Hey,
So as part of a experiment I am curious to be able to measure the resistance of a wire as I joule heat it under water to be able to get a steady state temp vs current. My thought is to attach electrodes to a metal wire to put a current across it and measure a voltage drop(4 point probe). I would likely use insulated leads attached to the wire that i want to measure. Additionally I would put the wire in distilled water when I make the measurements. So my thought is that since the resistance of the water is so much greater than that of the water I should be able to get a relatively accurate measurements. Does this make sense or am I missing something.
Thanks
Matt
HappMatt said:
Hey,
Thanks
Matt
Makes perfect sense, except for the simple typo in your next to last sentence. You should be fine.
sense instead of since? not the first time and I actually meant to type it that way.
Thanks
Matt
HappMatt said:
... So my thought is that since the resistance of the water is so much greater than that of the water I should be able to get a relatively accurate measurements...
Your typo was saying that you plan to compare the resistance of the water to the water (itself).
