Measurability and Lebesgue integral of complex functions
DavideGenoa
Hi, friends! I think that it is correct to say that, given a measure space ##X##:
  • if ##f:X\to\mathbb{R}##, ##\tilde{f}:X\to\mathbb{C}## and ##\forall x\in X\quad f(x)=\tilde{f}(x)##, then ##f## is measurable if and only if ##\tilde{f}## is;
  • ##f:X\to\mathbb{C}## is Lebesgue integrable if and only if both ##\text{Re}f:X\to\mathbb{R}## and ##\text{Im}f:X\to\mathbb{R}## are; in that case ##\int_X f(x)d\mu=\int_X \text{Re}f(x)d\mu+i\int_X \text{Im}f(x)d\mu##.
Am I right? ##\infty## thanks!
Second statement looks OK.
First statement is confusing - I can't understand the relationship and/or difference between these two functions.
Likes DavideGenoa
I mean: the Borel algebra of ##\mathbb{R}## and ##\mathbb{C}## are different, but I have convinced myself of that equivalence because I think that the Borel sets of ##\mathbb{R}## are Borelian as subsets of ##\mathbb{C}## and any Borel set belonging to ##\mathbb{C}## contained in ##\mathbb{R}\subset\mathbb{C}## is a Borel set considered as a subset of ##\mathbb{R}##; therefore I think that our function, which can be considered as a complex or real function defined on the measure space ##X## with measure ##\mu##, is measurable with respect to the Borel algebra of ##\mathbb{R}## (in the sense that the counterimage of any Borel set is ##\mu##-measurable), i.e. as a real function, if and only if it is with respect to the Borel algebra of ##\mathbb{C}##, i.e. as a complex function.
Thank you so much again!
Since the domain (X) is the same real line in either case, the issue you are raising is not relevant. X is the measure space. The range of the function does not come into play.
Likes DavideGenoa
Thank you so much!
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
