Can I Accurately Measure Temperature with 3 1/2 Digit Equipment?
The discussion focuses on measuring temperature variations over a distance of 100 meters using 3 1/2 digit equipment, with a total of 55 measurements taken. The user has calculated the mean, standard deviation, and standard error for the data collected. The main concern is how to incorporate the equipment's accuracy of +/- 5% and +/-3 digits into the analysis. Suggestions include considering the propagation of uncertainty to accurately reflect the measurement's reliability. Resources were shared to help clarify how to integrate accuracy into the measurement process effectively.
gnurf
In an attempt to determine how the temperature varies over a distance of 100m, I have taken five temperature measurements for every 10 meters, for a total of 55 measurements. I have then, for each dataset of N=5, calculated the mean value, standard deviation and standard error. Finally, I've plotted the mean value with error bars in what I believe is the most accurate and informative way to represent this data (mean temperature on the y-axis, and distance on the x-axis).
So far so good I think, but how do I include the accuracy of the, say, 3 1/2 digit measurement equipment if it was specified as accurate to within +/- 5% and +/-3 digits?
dlgoff said:
Where to start? Here maybe?
http://www.ni.com/white-paper/4439/en/
Thanks, but I didn't find what I was looking for at that url.
What I described above is basically a four step process (measure-->calculate mean-->calculate standard deviation-->calculate standard error) and I'm wondering at what stage it makes the most sense to take the 5% accuracy of the sensor into account. E.g., can I slap it onto the end of said four step process and simply increase the standard error by 5% (I'm guessing not, but I'm asking in order to clarify the problem).
Okay. You want Propagation of Uncertainty.
This looks good for that: http://www.rit.edu/cos/uphysics/uncertainties/Uncertaintiespart2.html#propagation
from http://www.rit.edu/cos/uphysics/uncertainties/Uncertaintiespart2.html
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
