Measuring Astronomical Distances
  • Thread starter Thread starter jay
A parsec is defined as the distance at which one arcsecond subtends an angle of one arcsecond between the Earth and the Sun, equating to about 3.26 light years. Parallax measurements can extend to nearly a hundred parsecs with precise instruments capable of sub-arcsecond resolution. For greater distances, Cepheid variables serve as standard candles, allowing astronomers to calculate distances based on their luminosity and apparent magnitude. Additionally, the redshift of light from distant galaxies provides another method for measuring astronomical distances, indicating how fast they are moving away. These various techniques form a "cosmic distance ladder," enabling cross-verification and calibration of measurements across different scales.
jay
Hai..
One 'parsec' is the distance from a star which makes an angle of 1''(1/60 of a degree)with the sun and earth(1.5*10^8 km).So by measuring an angle of 1'' we can measure to a maximum of 2 parsec.
But this only about 7 light years and we are speaking of much much bigger astronomical distances.How these are measured.
Thanks...
Jay
Astronomy news on Phys.org
A second of arc is actually one 1/60 of 1/60 of a degree -- 1/3600 of a degree.
Parallax can actually make measurements all the way out to nearly a hundred parsecs. You just need equipment that is capable of measuring angles in a sub-arcsecond range. An instrument that can only measure an arcsecond resolution would not be very useful, since only one two stars are that close.
Beyond parallax, we can use stars like Cepheid variables to measure distance. Cepheids have a particular relationship between the period of their variation and their total luminosity (how much total energy per unit time the star is producing). If you can measure the period, you can calculate the luminosity. If you know the luminosity (how bright the star is up-close) and the apparent magnitude (how bright the stars is from where we are), you can calculate its distance.
Even beyond that, we can use the redshift of light from distant galaxies to measure their distances. The farther away a galaxy is, the faster it is moving away from us, and the more its light is redshifted.
V good explanation:smile:
The different methods for measuring distances (e.g., parallax for "close" stars, standard candles for more distant galaxies, etc.) have overlapping ranges where they can be applied. So each method can be used to calibrate/check the other. I forget the name of this procedure...the "cosmic distance ladder" or something like that.
The closer the object, the better the measurement. The more distant, the more uncertainty.
another good description...
http://www.straightdope.com/mailbag/mstardistance.html
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
