Measuring Deer Antler Volume
  • Thread starter Thread starter erobz
  • #31
Oh. A suspended spring scale. I am such a stupidhead. :sorry:
  • #32
Thanks, Jack.
Some expensive balances are designed with the ability to do this. I've used a small digital scale. I built a jig that allowed me to suspend an object below the scale on thin fishing line. It wasn't difficult to do. It looked sort of like this (you'll have to imagine how the scale is supported):
If the object isn't dense enough to sink well on its own then you'd need to add a dense weight.
This idea is used to estimate body fat percentage. You are weighed in air and then submerged in a tank, sitting on a seat attached to a scale. I did this once as part of a class. It was kind of fun.
But for antlers it's probably not worth the trouble. The guys in that paper I linked above used the overflow method.
  • #33
All that is necessary to obtain the volume is to put the tank on a balance. No need for an overflow of any sort. Push the antlers down into the water until covered, not touching the bottom, and note the change of reading on the balance, in grams. That is the volume of the antlers in cubic centimetres.
  • #34
Except that you're trying to read off grams from a scale that is designed to measure tonnes (that's how big it would have to be to hold the largest set of antlers).
(see post 25)
  • #35
The balance would need to be counterweighted against about 300 kg of water, then the difference measured. That would require a very sensitive balance, where a difference of 1 gram will move 2 x 300 kg = 600 kg to settle in a new position.
Weighing the force difference in the balance, measured without the balanced masses moving, would give the fastest and most accurate result.
  • #36
But wouldn't that change of reading NOT include the volume of the antlers already submerged without pushing them down? For example, what if the antlers sink completely below the surface (on the bottom or not), on their own? Then the reading is just the combined weight of the tank and the antlers.
  • #37
Baluncore said:
...300 kg of water...
Pending erobz's responses to some of my questions, I think 300kg is conservative, depending on scope-of-use.
If this were to hope to challenge the current system, it would need to support the maximum possible dimensions of any antler set.
Moose antlers can spread 2m wide and 1m long. You would need a 2m x 1m x 1m tank - that's 2,000kg.
But we'll see.
  • #38
When you dip anything into the tank, it has upthrust due to its displacement volume. If you hold the object rigid, then there is an equal downward reaction force on the balance. The weight of the object is not relevant if the object is held rigidly.
Likes jack action
  • #39
I was being conservative in the opposite direction to you. For 1 gram = 1 ml = 1 cc resolution, neither 1 in 3x105, nor 1 in 2x106 is good.
So dispense with the tank of water and the balance, submerge the antlers in a lake, holding them fully submerged with a wire from the scales. The change in weight, in air, then in water, will give the volume of water displaced by the volume of the antlers. If needed, correct that value for density variation due to temperature, or salinity for seawater.
  • #40
If antlers float. What if they don't?
  • #41
They will be held down by the solid wire that connects them to the scales.
  • #42
If they sink, they don't need to be held down, but it also means you have a to use a different technique to weigh the antlers.
  • #43
Since the wire is rigid, it can push down or pull up, and the scales using a load-cell, can read and display ±weight, as required by antler density.
Likes DaveC426913
