Measuring the current in an electrosurgical unit
Finding a suitable ammeter for measuring current in an electrosurgical unit (ESU) has proven challenging, particularly for non-engineers. The current in question operates at RF frequencies between 350kHz and 4MHz, with a range of 200-1000mA, necessitating a non-invasive clamp-on device that connects to a computer for real-time measurements. Current probes designed for oscilloscopes are available, but they may complicate data capture and analysis. RF meters exist but often have limited frequency ranges, making them unsuitable for this application. Tektronix has been identified as a potential provider of an appropriate current probe, and further exploration of specialized companies is recommended for solutions.
nateg
I have been trying to find an ammeter that can perform a specific task and failing miserably. I would appreciate any help I can get. and as you may soon notice, I have no engineering background.
I am trying to find a non-invasive method for measuring the current generated in an electrosurgical unit (ESU) - the device that powers a bovie electrocautery device. The device changes voltage to keep power constant, depending on the amount of current passing through the a patient (resistance is constantly changing). The current that is used is in RF frequencies (350kHz-4MHz), to limit the effects on heart electrophysiology, and runs between 200-1000mA.
I need a clamp on device that can be connected to a computer to give me real time measurements of the current while the bovie is in use.
I cannot find an ammeter that will operate in RF frequencies and within those parameters.
Does anyone know of a device commercially available that can do this? Does this type of device have to be custom built?
I would appreciate any help I can get... thanks.
You need a current probe. You can find plenty of them on market going up to few Mhz and several dozens of amps.
If you know of one that you think could work, I would really appreciate it. I have been trying to find one for some time and I cannot. Please let me know.
There are a variety of clamp-on probes intended for use with oscilloscopes. Of course, oscilloscopes are a natural instrument to visualize and measure in this range, but setting the ranges, zeroing, and capturing the information via labview might be a mess.
RF meters are readily available that will plug into the 50 ohm outlet of the probe. Unfortunately, these tend to have a lower range between 10 and 50 MHz.
So, as far as I've found you're either stuck with a PC controlled scope and probe or a probe with a custom RMS converter.
Sorry I couldn't cook up something easier.
- Mike
thanks for your help. i am calling these companies. I will let you guys know when i find a solution.
I am not endorsing any company. And I have not received any products yet. But, Tektronix was the only company that was able provide/sell an appropriate current probe. They were also very helpful. FYI, if anyone needs something similar.
