Measuring the Resistance of a Wire
Measuring the resistance of a wire requires maintaining a constant current to ensure accurate results. Variations in current can lead to changes in temperature, affecting the wire's resistance due to heat generation. A steady current allows for consistent readings of potential difference (p.d.) and current, which is crucial for plotting resistance against length. The relationship between resistance and temperature is significant, as resistance in metals typically increases with temperature. Keeping the current constant is essential for reliable data in the lab experiment.
Peter G.
Hi,
First and foremost, I hope this question doesn't sound stupid!
I am doing a lab for school in which I have to measure the resistance of a wire. As part of that, I have to measure the p.d across the wire and the current through it. After collecting my results my teacher said that I should have kept the current constant throughout... He wasn't in today so I couldn't ask him why?
Why should I keep the current constant?
Thanks,
Peter
Peter G. said:
Hi,
Thanks,
Peter
That will depend upon the details of the lab procedure and how you're expected to handle the collected data for your writeup. Are there particular graphs you're expected to plot?
Note also that if the wire has resistance it'll be generating heat when current flows through it. More current means more heat per unit length. How does resistance vary with temperature for metals? For a given current the steady-state temperature of the wire will be constant (the temperature will settle at a point where the radiated heat = generated heat).
I am expected to plot a graph of resistance against length. Thanks for the response, I know acknowledge the importance of setting the current constant!
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
