Understanding Sound Waves: Measuring Speed and Wavelength
In summary, the sound waves in the tube are resonating and the distance AB is half the wavelength of the sound-wave in the air. The speed of sound in air is determined by the frequency of the sound-wave and the distance between the points of incidence and reflection.
Nikitin
735
27
Hi guys, I have problems with a high-school assignment:
http://img843.imageshack.us/img843/3748/74698735.png
An experimenter tries to determine the speed of sound in air. He tries to lower and elevate the water in the tube at the same time as he hits on the fork, until he hears an increase of the tone. He marks the spot with A. He repeats the same thing and finds a new spot. He marks it "B". The fork has a movement frequency f=440hz.
1) Determine why the air in the tube sends out sound of the same frequency as f?
2) Explain that the distance AB is half the wavelength of the sound-wave in the air.
3) Calculate the speed of sound in air.
v=f*[lambda]
1) Because the fork vibrates at 440 hz, thus it must send out 440 complete sound waves per second down the tube. Correct?
2) OK, here is the tricky question. I know that the water reflects the sound waves, and at point A & B the reflected sound waves and the incoming soundwaves interfere, thus increasing the amplitude and increasing the tone of the new wave (new wave = incoming wave + reflected wave).
I am finding it extremely hard to prove that distance AB = 0.5*[lambda]
3) No problem. v=f*2*(AB) This part is pretty easy.
Any help is highly appreciated..
Are you sure that interference always increases the amplitude?
no, but if it matches the frequency of the other wave and creates resonance (which it does in the post)..
Why does the experimenter only hear the increase in amplitude when the water is at certain heights?
Edit: it might help to try to draw the sound wave inside the tube.
Because that is when the reflected sound waves from the water start to resonance with the incoming waves from the fork?
So if the water level is a bit too high or a bit too low the entire thing gets out of sync and we won't see an increase in tone?
I'l try drawing them sound waves in the tube
Nikitin said:
So if the water level is too high or too low the entire thing gets out of sync and we won't see an increase in tone?
Bingo. Two waves will only interfere constructively (in a way which results in an increase in amplitude) if they are in phase.
When the column of air inside the tube is resonating, its length is such that the incident and reflected sound waves are in phase with each other.
Edit:
Look at this diagram once you've had a go at drawing the sound waves yourself, try to imagine what the drawing would look like if the water level was somewhere between A and B
http://image.wistatutor.com/content/waves/resonance-end-correction.gif
Hm, but the amplitude would increase even if the wave-front collisions are not perfect (let's say a sound-wave front of high pressure hits a sound-wave front which borders between low and high pressure but is mostly high pressure).. Right?
I will study your link, hopefully I can solve the second problem with its help.
OK, I sat down and started thinking. I believe I got it now kind-of, but I am still wondering about the question abovealso: those signs on the right, representing the actual sound-wave, aren't they a bit badly drawn? Shouldn't the sound-wave be made up of ONLY of high-pressure to low pressure waves, instead of just a low-pressure wave representing the negative part of the wave and a high-pressure wave representing the wave-top?
The amplitude of the sum wave would indeed still increase if the waves were a little out of phase, however it will be greatest when they are exactly in phase, and will decrease as they get more out of phase until eventually it reaches 0 (at this point the waves are exactly out of phase).
As a result of this the sound will be more audible the closer the waves are to being exactly in phase, and as it happens because of how resonance works (think feedback loops), the amplitude of the sound will actually fall away very quickly as the waves inside the tube become out of phase.
You can ignore most of the diagram (the stripes on the side are, incidentally, another way of representing the wave, look at the pattern of their closeness and how it is related to the amplitude of the standing wave inside the tube), i just wanted to provide a general clue about the shape of the waves.
Edit:
Yes they are poorly drawn, my best guess is that at some point the picture was resized, which led to be the "stipes" becoming rather unhelpful
Hi. We have only learned about the transverse waves and the longitudinal waves and using sine to represent periodical movements and regular graphs to represent the power of longitudinal waves. About the soundwave, we haven't been thought the models (like the ones used in this link http://www.asc-csa.gc.ca/images/neemo_open_tube_t.gif ) used in your picture.
PS. sry for my english.
exactly what are these red lines representing? http://en.wikipedia.org/wiki/File:OpenCylinderResonance.svg
Bump? This should be a pretty simple question.. I believe these lines are a function for the increase and decrease of air pressure, but I would appreciate a proper explanation of them in this http://image.wistatutor.com/content/waves/resonance-end-correction.gif picture
both of the waves at example 2 are having their positive peak, right?
EDIT: I think I see now why it is 1/2. It is obvious that the reflection of the line would be imperfect, and thus the two halves of the tube wouldn't be symmetrical. I'l take a look at this tomorrow (hope someone can post a complete explanation.. I would rly appreciate it!).
Anyway, thank you L-x, your help really put me to the right track. Anyway I'm off to chat with m8's.
What is the speed of sound?
The speed of sound is the distance that sound waves travel in a certain amount of time. It is different for different mediums, but in dry air at sea level, the speed of sound is approximately 343 meters per second.
How do you measure the speed of sound?
The speed of sound can be measured by using a device called a sound wave generator, which emits a sound at a known frequency. By measuring the time it takes for the sound wave to travel to a certain distance and back, the speed of sound can be calculated using the formula speed = distance/time.
What factors affect the speed of sound?
The speed of sound can be influenced by several factors, including temperature, humidity, and the medium through which the sound is traveling. In general, sound travels faster in warmer temperatures, as the air molecules are moving faster and can transmit the sound waves more quickly.
Why is the speed of sound faster in solids than in gases?
Sound travels faster in solids because the molecules in solids are closer together, allowing sound waves to travel more quickly and efficiently. In gases, the molecules are further apart and have more space to move around, which slows down the transmission of sound waves.
How is the speed of sound used in everyday life?
The speed of sound has many practical applications in everyday life, such as in the design of musical instruments, the development of communication systems, and the calculation of distances using echolocation. It is also important in the fields of meteorology and seismology, where the speed of sound can help predict weather patterns and detect earthquakes.
