Measuring up to ~2T magnetic fields
For measuring magnetic field flux densities around ~2T, safety is paramount due to the potential hazards of ferromagnetic materials. The method of measurement depends on factors such as the size of the sensor, whether the field is AC or DC, and the required precision. Hall effect probes, integrating coils, and proton resonance are viable options, with integrating coils being the simplest for achieving 1% precision if a volume of at least 1 cm3 is available. Building an op-amp circuit with a DC voltmeter is a straightforward approach for this setup. The discussion emphasizes careful consideration of the measurement context and requirements.
metalplastic
What do you propose as a quick DIY method for measuring magnetic field flux densities around ~2T?
I would first and foremost recommend to be very careful with fields at ~2T. A piece of ferromagnetic material can do a lot of damage and get permanently lodged in whatever it is you are using for the field. Is this something like an MRI magnet? What do you need the measurements for?
A lot depends on the volume of field avialable (i.e., size of sensor), whether it is an dc or ac field, the precision required, ease of construction, etc.
I have used many types, including Hall effect probes, integrating (flip) coils, proton (nuclear magnetic) resonance. If you have at least 1 cm3 of volume, and you want a 1% precision measurement, an integrating coil is easiest, and does not require anything more than building an op-amp circuit and using a dc voltmeter.
See my post #27 in https://www.physicsforums.com/showthread.php?t=70290&highlight=flip+coil&page=2
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
