Mechanical acceleration and veloctiy relationship
8 replies · 3K views · last reply
awesome4444
The motion of a particle is expressed by a=42-12x2 where a is in m/s2 and X is in m, with the initial condition: v=0 when x=0 and t=0
Determine v when X=6
Determine X when v becomes 0 again
I tried using a=dv/dt so i took the anti derivative of a to find the equation of v which turned out to be 42x-4x^3 + c and then pluged in 6 for x and found v=-612m/s
but then for the second part when i tried finding the roots of the equation b i have two answers +3.2 and -3.2
So i don't know if i should use +3.2 or -3.2
Can someone tell me if I am doing anything wrong? :(
Note that a = [itex]\frac{dv}{dt}[/itex]
and so v = [itex]\int[/itex]adt but v [itex]\neq[/itex][itex]\int[/itex]adx.
so we would integrate (a*dt) but I am not sure wat dt is :P
I think that you know that the symbol
[itex]\int[/itex]...dt
means
'integrate ... with respect to t'
adt does not mean that a is multiplied by anything.
You can't integrate your equation with respect to t as your equation doesn't rely on t (which it should in an ideal world). Maybe you copied down wrong?
One can use the following:
a = [itex]\frac{dv}{dt}[/itex] = [itex]\frac{dv}{dx}[/itex][itex]\frac{dx}{dt}[/itex] = v[itex]\frac{dv}{dx}[/itex]
hence ∫a dx = ∫v dv = [itex]\frac{v^{2}}{2}[/itex] + constant
Clever.
I was reminded about that other method by a recent post on PHYSICS FORUMS!
