Mechanics: Inelastic Collisions Questions
  • Thread starter Thread starter Jadenag
    Mechanics
Inelastic collisions involve understanding the coefficient of restitution, which relates the velocities before and after a collision. The formula for inelastic collisions is velocity of approach equal to negative e times velocity of separation. Directionality of velocities is crucial, as it varies based on the dimensionality of the collision rather than the type of collision. The coefficient of restitution does not apply to kinetic energy in the same way; instead, conservation of momentum must be used to determine directions accurately. Understanding these principles is essential for solving problems related to inelastic collisions effectively.
Jadenag
Guys this is my first post on this site. Not sure If this is the correct thread but lmk?
Im having a tough time dealing with inelastic collisions. I am not entirely sure about the coefficient of restitution. I used to study a formula in Physics which was speed of aproach= Speed of separation for elastic collisions. Now in mechanics I am using the same formula but its velocity of approach=(-e)(velocity of seperation) I believe. I firstly am having an issue with the directions of the velocities. Previously with elastic collisions Id just add the two in opposite directions and subtract the two in the same direction. Also. This coefficient of restitution. Is it also applicable to the Kinetic Energy before and after the inelastic collision? Is this also a formula: Initial K.E= (-e)(Final K.E) ? Thankyou.
Mathematics news on Phys.org
"Adding in opposite directions and subtracting in the same direction" has nothing at all to do with "elastic" collisions. It has to do with whether you are dealing with collisions in one (on a line), two (on a plane), or three (in space) dimensions.
Yes, the total energy after the collision is equal to the total energy before the collision times the "coefficient of restitution". You will also need to use "conservation of momentum" to get directions right.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
