Mechanics Problems: Tensile Forces and Pressure
A uniform beam weighing 150 N is supported by a hinge and a cable, forming a 3:4:5 triangle with a 300 N weight at its end. The discussion revolves around calculating the tension in the cable and the forces at the hinge. Participants analyze the forces acting on the beam, noting the importance of considering both the weight and tension vectors. A suggestion to take moments about the hinge leads to the calculation of torques, ultimately resulting in a torque of 1500 Nm. The problem is resolved with the final force calculated as 625 N, and the user expresses readiness to tackle the next question.
asleight
A uniform, horizontal beam of length 4 weighs 150 N. It is connected to a wall by a hinge and is held horizontal by a cable of length 5; it holds a 300 N weight at its end away from the wall. The cable and the beam form a 3:4:5 triangle with the wall.
\sum_{i=1}^n\textbf{F}_i=m\textbf{a}_i=0, because the system is not accelerating.
The forces acting upon the end of the rod are half of its weight, the hanging weight, and the tension. I've solved for textbf{T}[\tex] to no avail. What am I doing incorrectly?
Hi asleight! :smile:
Show us what you tried, and where you're stuck, and then we'll know how to help. :smile:
Examining the FBD for the end of the rod, we see:
\sum\textbf{F}=\textbf{F}_{g,weight}-\textbf{T}\sin{\theta}=0, solving for tension, we find:
\textbf{F}_{g,weight}/\sin{\theta}=\textbf{T}, is that really it?
Nooo … F and T are vectors, and they're not parallel, so that can't be right can it?
You've left out the unknown force at the hinge.
Since it's unknown, what technique do you know that will give you an equation without it? :smile:
I don't see what the problem is. Parts (b) and (c) ask to solve for the forces applied by the hinge so I don't know where to go on from here. I'm not so intuitively-savvy today, it seems. I have other questions, too. GAH. Haha.
Try taking moments about the hinge.
Solving for the sum of the torques, we find 1200Nm being applied in the clockwise direction by the hanging mass, 300Nm by the rod itself, also applied in the clockwise direction. Then, we have to cancel that with the torque due to the chord. So, the torque is 1500Nm.
\tau=r\times F=rF\sin{\theta}=3rF/5=1500,
solving for F, we find: F = 625 N, is that right?
Nevermind, I finished that problem. The next one'll be posted shortly.
