Melting Nickel Ball: Temperature & Radius Effects
The discussion focuses on how deeply a nickel ball can melt into an ice block, influenced by various factors such as thermal diffusivity, temperature difference, gravitational acceleration, latent heat of melting, thermal conductivity, and the ball's radius. The derived formula for the melting distance is d = (ΔT λ r^4 g) / (κ^2 L), incorporating the density ratio of the ball to ice. A nickel ball of 1 cm³ can release 3.9 J for each degree Celsius cooled, while melting 1 mL of ice requires 312 J. Observations from the video suggest that the ball melts approximately 3-4 times its volume, indicating significant heat loss, likely due to steam production and thermal energy escaping when water flows out. Overall, the analysis highlights the complex interplay of thermal dynamics in this melting process.
Borek
Mentor
How far down can a nickel ball of radius r and temperature Tn melt into the ice block of temperature Ti? Watch the video and state your assumtpions...
The distance should depend on the thermal diffusivity of the ball (κ), the temperature difference between the ball and ice (##\Delta T = T_n - T_i##), the gravitational acceleration constant (g), the specific latent heat of melting for ice (L), the thermal conductivity of the ice (λ), and the radius of the ball (r). A combination of these variables that has the dimension of length and is physically plausible is
## d = \frac{\Delta T λ r^4 g}{κ^2 L} ##
The distance may also involve the dimensionless ratio of the density of the ball to that of the ice.
Assume a ball of 1 cm3. The specific heat of nickle is 0.44 J/gK and its density is 8.9 g/mL, so it should release 3.9 J for each degree of Celcius cooled. The heat of fusion of ice is 335 J/g and its density is 0.934 g/mL, so melting 1 mL of ice requires 312 J of energy. So, a ball ideally should be able to melt its own volume of ice for every 80oC above 0oC. Based on blackbody radiation curves, red hot objects tend to be ~600oC, which would correspond to melting ~ 7-8x the volume of the ball. In the video, the ball melts ~ 3-4x its size, indicating that a lot of the heat is lost (for example, you see a lot of steam produced, meaning that not all of the energy goes into melting the ice, and a good deal of thermal energy is probably lost when the water pours out of the side of the ice block).
Likes billy_joule
Thread 'RIP George F. Smoot III (1945-2025)'
https://en.wikipedia.org/wiki/George_Smoot https://physics.berkeley.edu/people/faculty/george-smoot-iii https://apc.u-paris.fr/fr/memory-george-fitzgerald-smoot-iii https://elements.lbl.gov/news/honoring-the-legacy-of-george-smoot/ https://www.nobelprize.org/prizes/physics/2006/smoot/facts/ https://www.aps.org/publications/apsnews/200611/nobel.cfm https://inspirehep.net/authors/988263 Structure in the COBE Differential Microwave Radiometer First-Year Maps (Astrophysical Journal...
