Understanding the Charge Distribution at the Metal-Semiconductor Interface
In summary, the Fermi energy of the metal does not change when in contact with an n type semiconductor due to the high electron density in metals. The Schottky barrier in metal-semiconductor contact remains constant under both forward and reverse applied voltages, and the direction of electron flow determines the type of bias. Forward bias occurs when electrons are injected from the semiconductor to the metal, while reverse bias occurs when electrons are injected from the metal to the semiconductor. The thickness of the charge layer in the metal is very thin due to the high density of free carriers, resulting in a smaller potential across the metal compared to the semiconductor. Under a positive bias on the metal side and negative on the semiconductor side, there will be a layer of immobile
Robotduck
TL;DR Summary
Metal Semiconductor Contact
Assume n type semiconductor:
1) Can the fermi level of metal change when it makes contact with the n type Semiconductor ? What assumptions do we make in ideal situation ?
2) Is the Schottky Barrier in Metal Semiconductor contact remains constant with an applied forward or reverse voltage ?
3) On what reasons, do we say that the metal semiconductor junction is forward biased when applying positive on the metal side and negative at the semiconductor side, since both have electrons as a majority carriers .
Thank you in advance !
a) Even if some electrons are transferred from the n-type semiconductor to the metal, the Fermi energy of the metal doesn’t change because of the extremely high electron density in metals.
b) The Schottky barrier - a barrier for electrons to move from the metal to the semiconductor - is the difference between the work function of the metal and the electron affinity of the semiconductor. It doesn't change under an applied forward or reverse voltage.
c) Forward and reverse bias define whether the electrons are injected from the semiconductor to the metal or vice versa. The forward and reverse currents differ from each other because the injected electrons have different barriers to surmount.
Have, for example, a look at
Lecture 9: Metal-semiconductor junctions - nptel
Thank you so much for the reply.
But Can you please elaborate more on this:
"b) The Schottky barrier - a barrier for electrons to move from the metal to the semiconductor - is the difference between the work function of the metal and the electron affinity of the semiconductor. It doesn't change under an applied forward or reverse voltage."
Why does not it change ?
So, you mean : if the electrons are injected from the semiconductor to metal: that is Forward biased case and if the flow is from metal to semiconductor then this is reverse biased case ?
Also, electrons from semiconductor to metal is considered as diffusion but how does electrons from metal to semiconductor flow is drift ? How do we get the Delta function of negative charge at the surface of the metal ?
Thank you so much
In an ideal case, the work function of the metal and the electron affinity of the semiconductor are material properties.
Thank you so much.
One last question on this:
How do we get a negative charge sheet on the metal side in a Metal -n type semiconductor contact ?
Thank you
"Since the density of free carriers is very high in a metal, the thickness of the charge layer in the metal is very thin. Therefore, the potential across the metal is several orders of magnitude smaller than that across the semiconductor, even though the total amount of charge is the same in both regions."
see Fig. 3.3.1 in https://ecee.colorado.edu/~bart/book/book/chapter3/ch3_3.htm
Likes Mentz114
Please correct me if I am wrong:
With positive bias on metal side and negative on semiconductor- it will attract the electrons from the metal leaving immobile positive ions at the metal -semiconductor interface on the metal side ( this positive ion layer ) and on the semiconductor side - due to negative bias we will have negative charge ( not ions) on the semiconductor side. Do I have this right ?
Related to Understanding the Charge Distribution at the Metal-Semiconductor Interface
1. What is a metal semiconductor contact?
A metal semiconductor contact is a junction between a metal and a semiconductor material, where the two materials come into physical contact. This junction is important for the functioning of electronic devices, as it allows for the flow of electrons between the metal and semiconductor.
2. How does a metal semiconductor contact work?
A metal semiconductor contact works by creating a barrier between the metal and semiconductor materials. This barrier, known as a Schottky barrier, prevents the flow of electrons from the metal into the semiconductor. However, when a small voltage is applied, the barrier can be overcome and electrons can flow from the metal into the semiconductor, creating a current.
3. What factors affect the performance of a metal semiconductor contact?
The performance of a metal semiconductor contact is affected by several factors, including the type of metal and semiconductor materials used, the cleanliness of the contact surface, and the temperature at which the contact is operating. Additionally, the presence of impurities or defects at the interface can also impact the performance of the contact.
4. What are some applications of metal semiconductor contacts?
Metal semiconductor contacts are used in a variety of electronic devices, including diodes, transistors, and solar cells. They are also important for the development of integrated circuits and other semiconductor-based technologies.
5. How can the performance of a metal semiconductor contact be improved?
The performance of a metal semiconductor contact can be improved by carefully selecting the materials used, ensuring a clean contact surface, and optimizing the temperature and voltage conditions. Additionally, techniques such as doping and surface treatments can also be used to improve the performance of the contact.
  • Quantum Physics
  • Classical Physics
  • Atomic and Condensed Matter
