Why Does Metallic Radius Decrease Across a Period in Transition Metals?
  • Thread starter Chemist20
  • Tags
    Bond
In summary: Basically, as the period goes by and the orbitals become more contracted, less bonding, GREATER RADII!
Chemist20
86
I am so confussed..
Talking about transition metals, in the book it says that the general trend in a period is for the metallic radii to decrease due to increase of Zeff. But I don't think this makes sense.
I think: we are talking about metallic radii not IONIC! If its metallic, then the radii would be half the distance between the two metals. hence, the greater bonding, the smaller de radii. Hence, as the period goes by and the orbitals become more contracted, less bonding, GREATER RADII!
why am i wrong?
please help!
Chemistry news on Phys.org
Well that's the thing!
metallic radius is defined as half of the distance between two metals in a metal bond.
ionic radius on the other hand is different. that's why i think that talking about zeff should be to explain the ionic radius not the metallic radius.
metallic radius has to be related to the strenght of the m-m bond.
Why do you think that more contracted orbitals are less bonding? It is the other way round!
Furthermore, at least main group metals are well described as ionic cores surrounded by nearly free conduction electrons, the distance of the atoms being dictated by the radii of the ionic cores.
oh god yes.. hadn't realized the first part :)
okay, but then, why does the metallic radius increase as the group goes down? as the group goes down the overlap between metals is greater and hence should be a smaller metallic radii!
didn't quite get the last part of your comment .. :)
Your understanding of the trend in metallic radii for transition metals is correct. As you stated, the metallic radii decrease as the period increases, due to the increase in effective nuclear charge (Zeff). This means that the valence electrons are held more tightly by the nucleus, resulting in a smaller atomic radius. This is also known as the lanthanide contraction.
However, it is important to note that the trend in metallic radii is different from the trend in ionic radii. In ionic compounds, the size of the ions is determined by the balance between the attractive force of the opposite charges and the repulsive force of the electron shells. In metallic compounds, the size of the atoms is determined by the strength of the metallic bond, which is a result of the delocalization of electrons in the metal lattice.
In transition metals, the valence electrons are located in the d orbitals, which are closer to the nucleus compared to the s and p orbitals. This means that the electrons are more strongly attracted to the nucleus, resulting in a smaller atomic radius. Additionally, the d orbitals also have a higher energy, making them more easily contracted as the atomic number increases.
In summary, your understanding of the trend in metallic radii is correct. The decrease in radii as the period increases is a result of the increase in effective nuclear charge and the contraction of the d orbitals. It is important to differentiate between the trends in metallic and ionic radii, as they are determined by different factors. I hope this helps to clarify any confusion.
1. What is a metallic bond?
A metallic bond is a type of chemical bond that forms between positively charged metal ions and a sea of delocalized electrons. This bond is responsible for the unique properties of metals, such as high electrical and thermal conductivity, malleability, and ductility.
2. How does a metallic bond differ from other types of chemical bonds?
A metallic bond differs from other types of chemical bonds, such as covalent and ionic bonds, in that it is a bond between metal atoms rather than non-metal atoms. Additionally, unlike covalent and ionic bonds, metallic bonds do not involve the sharing or transfer of electrons, but rather the electrons are free to move throughout the metal lattice.
3. What factors affect the strength of a metallic bond?
The strength of a metallic bond is affected by several factors, including the number of valence electrons in the metal atoms, the size of the metal ions, and the arrangement of the metal atoms in the lattice. Generally, metals with more valence electrons and smaller ions will have stronger metallic bonds.
4. How does a metallic bond contribute to the physical properties of metals?
The unique properties of metals, such as high electrical and thermal conductivity, malleability, and ductility, are a result of the metallic bond. The free movement of electrons in the metallic lattice allows for the easy transfer of heat and electricity, while the lack of fixed positions for the metal ions allows for the malleability and ductility of metals.
5. Can metallic bonds form between different types of metal atoms?
Yes, metallic bonds can form between different types of metal atoms. This is known as an alloy, where two or more metals are mixed together. Alloys often have different properties than their individual component metals due to the unique arrangement of atoms and the resulting variation in the strength of the metallic bonds.
  • Chemistry
  • Atomic and Condensed Matter
