How Do You Compute the Electric Potential Using the Method of Image Charges?
The discussion focuses on using the method of image charges to compute the electric potential between two semi-infinite grounded conducting planes. The user proposes three image charges to satisfy boundary conditions, specifically two negative charges and one positive charge, and presents a potential equation that meets the criteria of zero potential at the planes. There is uncertainty about the justification for the chosen image charges and whether guesses are acceptable if they satisfy the conditions. The user also calculates the charge density on the planes, expressing it in terms of the potential's derivatives, and acknowledges a potential error in symmetry regarding the charge distribution. Overall, the conversation emphasizes the need for rigorous justification in applying the method of image charges.
BOAS
Hi,
I am learning about the method of image charges, but am struggling to sufficiently justify my answer. It appears to be correct, though it quite possibly isn't...
1. Homework Statement
(please see attached item)
Two semi-infinite grounded conducting planes (the shaded region in the figure, corresponding to ##x ≤ 0## or ##y ≤ 0)## meet at right angles. In the region between them (i.e. ##x > 0## and ##y > 0##), there is a point charge, at a distance ##d## from each plane, as indicated in the figure. Set the z axis such that the charge q is at ##z = 0##.
(a) To compute the potential between the planes you need three image charges. What is their magnitude and where should they be located?
(b) Compute the electric potential between the planes.
(c) Compute the electric charge density σ on the planes.
[/B]
My answer to part (a) is essentially a guess, based on creating a symmetrical situation. I don't know how to justify it properly, and would love some help regarding this.
I have said that I need 2 charges of -q and one of charge +q.
-q (-d, d)
-q (d, -d)
+q (-d, -d)
Are the coordinates that I think they should be placed at.
I then look at the potential, and see that ##V(x,y) = \frac{1}{4 \pi \epsilon_{0}} [\frac{q}{\sqrt{(x-d)^{2} + (y-d)^{2}}} - \frac{q}{\sqrt{(x+d)^{2} + (y-d)^{2}}} - \frac{q}{\sqrt{(x-d)^{2} + (y+d)^{2}}} + \frac{q}{\sqrt{(x+d)^{2} + (y+d)^{2}}}]##
which satisfies the conditions that at ##V(0,y) = 0## and ##V(x,0) = 0##
Am I on the right track here?
Thanks!
Looks good to me !
BvU said:
Looks good to me !
That is good to hear! I do feel like I have cheated somewhat though. Is there a rigorous method to go about this, or is a guess generally acceptable provided it can be shown to satisfy the conditions?
For part (c) I need to find the charge distributions on each plane. I have done that in the same way I would for a single plane, and the expressions look like they make physical sense to me.
##\sigma_{x} = - \epsilon_{0} \frac{\partial V}{\partial y}|_{y = 0} = - \frac{q}{2 \pi} [\frac{d}{((x - d)^{2} + d^{2})^{3/2}} - \frac{d}{((x + d)^{2} + d^{2})^{3/2}} ]##
and ##\sigma_{y} = - \epsilon_{0} \frac{\partial V}{\partial x}|_{x = 0} = - \frac{q}{2 \pi} [\frac{d}{((y - d)^{2} + d^{2})^{3/2}} - \frac{d}{((y + d)^{2} + d^{2})^{3/2}} ]##
I think this makes sense because as the charge distribution would not be constant along the planes
Doesn't look symmetric around y = x !?
try x = d and you'll see the error
[edit] yes the ##(x-d)^2 -d^2## should have been ##(x-d)^2+d^2##
Likes BOAS
Sorry, what doesn't look symmetric around y = x?
Edit - Fixed a typo in my ##\sigma_{x}## expression
