Method of Images: Infinite, charged wire above a grounded plate
The problem involves an infinitely long wire with charge density λ positioned parallel to and at a distance d above a grounded conducting sheet. The objective is to determine the potential V(x,y,z) above the sheet and the induced charge on the sheet.
  • The original poster attempts to apply the method of images by introducing an image wire with charge density -λ located below the sheet. They express uncertainty regarding the potential of an infinitely long charged wire, questioning whether it is infinite.
  • Some participants reference a specific discussion in Griffiths' book regarding the choice of reference point for potential, suggesting that an arbitrary point should be used instead of infinity.
  • Others discuss the potential expression and its simplification using properties of logarithms, indicating a connection to related problems in different texts.
The discussion is ongoing, with participants providing references to literature and clarifying concepts related to potential. There is an acknowledgment of the original poster's oversight regarding potential reference points, and suggestions for simplifying calculations have been made.
Participants are navigating the complexities of potential in electrostatics, particularly in relation to infinite charge distributions and grounded conductors. There is an emphasis on understanding the implications of the method of images and the mathematical treatment of logarithmic potentials.
SonOfOle
Given an infinitely long wire, with charge density [itex]\lambda[/itex], parallel to and a distance [itex]d[/itex] above an infinite, grounded, conducting sheet, what is the potential, [itex]V(x,y,z)[/itex] above the sheet?
What is the induced charge on the sheet?
This is a method if images problem. Construct a infinitely long wire with charge density [itex]-\lambda[/itex] a distance [itex]-d[/itex] below the plane of the sheet and then disregard the sheet (it creates the same potential, V=0, at the plane of the sheet).
However, I ran into a snag when I tried to find the potential of an infinitely long charged wire. Is the potential infinite?
No... if you have the Griffiths book please look at page 80. There is a very important discussion in there where students mostly pass reading it very fast!
Due to the argue in the last past of page 80, you can not choose the infinity as your potential reference point. you can choose it is a arbitrary point named a, for example so the potential of a infinite charged line will be:
(-lamda/ 2pi) Ln (r/a)
which r is the distance from the wire
aha! Thanks astrosona. That's something I've forgotten about.
In fact, due to the properties of logarithms, you can rewrite this as
[tex]\phi = -\frac{\lambda}{4\pi} \ln \frac{r^2}{a^2}[/tex]
which might make some things simpler to calculate, because [itex]r^2 = x^2 + y^2[/itex], and you no longer have to bother with square roots.
Your problem is pretty simple, but in Jackson's there is a similar problem with two grounded planes, meeting at right angles, with the line charge located at (x_0, y_0). :P
10K
