Metric for an observer in free fall two schwarzchild radii from black hole.
To find the metric for an observer in free fall two Schwarzschild radii from a black hole, the correct approach involves substituting r=2rs and dt=d(tau) into the standard Schwarzschild metric. This scenario can be treated as a radial trajectory, allowing for the simplification of d(theta) and d(phi) to zero. The user seeks clarification on these steps as they prepare for an upcoming general relativity exam. The discussion highlights common challenges faced by students in understanding complex concepts in gravitational physics. Overall, the inquiry emphasizes the need for clear guidance in applying general relativity principles.
Sae_Phys
Hi all,
I have a GR exam on tuesday and getting a bit confused as to how to find the metric for an observer in free fall a distance two schwarzchild radii from a black hole.
I know this is a bit of a basic question but I am just wondering if I am correct to substitute r=2rs and dt=d(tau) into the usual metric and simplify. Also does this class as a radial trajectory so can you set d(theta) and d(phi) =0 ... HELP!
SorryI realize I have posted this in the wrong place (new to this forum).
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
