Metric Space: Closure of B(x,1/2) Examined
In summary, the conversation discusses whether the closure of a closed ball in a metric space always contains a point y that is not in the ball, and whether the closure of a closed ball is equal to the set of points whose distance from x is less than or equal to the radius of the ball. It is determined that while the first statement is not always true, the second statement holds true in general.
ehrenfest
2,020
[SOLVED] metric space
If x and y are two points in a metric space and d(x,y) = 1, is it always true that the closure of B(x,1/2) does not contain y?
In general, is [tex] closure( B(x,r)) = \{z | r \geq d(x,z)\}[/tex]
Never mind. The answer is of course because closed balls are closed in a metric space. Why are closed balls in a metric space closed. Because their complement is open. Why is their complement open? Because, for any point x in the complement, let d be the distance from x to the closed ball. Then B(x,d/2) is a nbhd of x that lies in the complement. d is always nonzero and well-defined because otherwise x would be a limit point of the closed ball.
Hold on - this is not true. In the reals with the discrete metric, closure(B(x,1))={x}, while {z : 1>=d(x,z)}=R.
But what is true is that the closure of B(x,r) will always sit inside {z : r>=d(x,z)}.
I see. Thanks.
What is a metric space?
A metric space is a mathematical concept used to measure the distance between two points in a given set. It is defined by a distance function, also known as a metric, which satisfies specific properties such as non-negativity, symmetry, and the triangle inequality.
What is the closure of a set in a metric space?
The closure of a set in a metric space is the smallest closed set that contains all the points in the original set. It includes all the limit points of the set and is denoted by the symbol "Cl". In other words, the closure of a set is the set itself along with its boundary points.
What does "B(x,1/2)" represent in the context of the closure of a metric space?
In the context of the closure of a metric space, "B(x,1/2)" represents an open ball with radius 1/2 centered at the point x. This means that it includes all the points within a distance of 1/2 from the point x, but does not include the boundary points. It is denoted by the symbol "B" followed by the center point and the radius in parentheses.
What does it mean to examine the closure of B(x,1/2) in a metric space?
To examine the closure of B(x,1/2) in a metric space means to analyze the properties and characteristics of this set. This includes determining its limit points, boundary points, and whether it is open, closed, or neither. It also involves understanding how this set relates to the original set and how it affects the overall structure of the metric space.
Why is the closure of B(x,1/2) important in a metric space?
The closure of B(x,1/2) is important in a metric space because it provides a way to understand the behavior of the original set and its relationship to the entire metric space. It also helps to determine the completeness of the metric space and whether it contains all its limit points. Additionally, the closure of B(x,1/2) can be used to define other important concepts in metric spaces, such as compactness and connectedness.
