Metric Tensor Question: Special Relativity
Someone1987
I'm just wondering if the metric tensor (in its matrix form of 1 and -1's along the diagonal) is the same even when the direction of velocity of the "moving" frame isn't along the x-axis of the "stationary" frame but is in some arbitrary direction. This would obviously alter the Lorentz transformation matrix but it would seem to me that the metric tensor wouldn't change but I'm not sure. I'm just talking special relativity here so we don't need to generalize anything to general relativity. I'd appreciate any help. Thanks
You're correct. In a cartesan inertial frame the metric tensor is always (1,-1,-1,-1) irrespective of orientation. You can actually check this by implementing at arbitrary Lorentz transformation on this tensor and checking that the components don't change.
I've found it helpful to think about the metric tensor in terms of vector dot products, and a cooresponding basis.
You can cut relativity completely out of the question, and ask the same question for Euclidian space, where the metric tensor it the identity matrix when you pick an orthonormal basis.
That diagonality is due to orthogonality conditions of the basis chosen. For, example, in 3D we can express vectors in terms of an
orthonormal frame, but if we choose not to, say picking e_1 + e_2, e_1-e_2, and e_1 + e_3 as our basis vectors then how do we calculate the coordinates?
The trick is to calculate, or assume calculated, an alternate set of basis vectors, called the reciprocal frame. Provided the initial set of vectors spans the space, one can always calculate (and that part is a linear algebra exercise) this second pair such that they meet the following relationships:
<br /> e^i \cdot e_j = {\delta^i}_j<br />
So, if a vector is specified in terms of the e_i
<br /> x = \sum e_j a_j<br />
Dotting with e^i one has:
<br /> x \cdot e^i = \sum (e_j a_j) \cdot e^i = \sum {\delta^j}_i a_j = a_i<br />
It is customary to write a_i = x^i, which allows for the entire vector to
be written in the mixed upper and lower index method where sums are assumed:
<br /> x = \sum e_j x^j = e_j x^j<br />
Now, if one calculates dot product here, say with x, and a second vector
<br /> y = \sum e_j y^j<br />
you have:
<br /> x \cdot y = \sum (e_j \cdot e_k) x^j y^k<br />
The coefficient of this x^j y^k term is symmetric, and if you choose, you
can write g_{jk} = e_j \cdot e_k, and you have the dot product in
tensor form:
<br /> x \cdot y = \sum g_{jk} x^j y^k = g_{jk} x^j y^k<br />
Now, for relativity, you have four instead of three basis vectors, so if you choose your spatial basis vectors orthonormally, and a timelike basis vector normal to all of those (ie: no mixing of space and time vectors in anything but a Lorentz fashion), then you get a diagonal metric tensor. You can choose not to work in an "orthonormal" spacetime basis, and a non-diagonal metric tensor will show up in all your dot products. That decision is perfectly valid, just makes everything harder. When it comes down to why, it all boils down to your choice of basis.
Now, just like you can think of a rotation as a linear transformation that preserves angles in Euclidian space, the Lorentz transformation preserves the spacetime relationships appropriately. So, if one transforms from a "orthonormal" spacetime frame to an alternate "orthonormal" spacetime frame (and a Lorentz transformation is just that) you still have the same "angles" (ie: dot products) between an event coordinates, and the metric will still be diagonal as described. This could be viewed as just a rather long winded way of saying exactly what jdstokes said, but its the explanation coming from somebody who is also just learning this (so I'd need such a longer explanation if I was explaining to myself).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
