Michelson Interferometer
In summary, we can use the equations y=m(lambda)/2 and y=θd to calculate the distance between the plane of constant phase and each fringe, and use the small angle approximation to find the slope of the line between A and B on the uneven mirror's surface with respect to the plane of constant phase.
Melawrghk
145
Basically, there is an interferometer with one perfect mirror and a mirror with varying thickness across it. You shine parallel coherent light, wavelength 633nm, and see an interference pattern. The interference batter is wavy dark and light fringes of varying thickness. Two neighbouring fringes have their centers marked, A and B and those are separated by 3mm.
Find the slope of the line between A and B on the uneven mirror's surface wrt plane of constant phase of the wave.
y=m(lambda)/2
I understand why thick fringes are formed - the source isn't a point source, so it is a beam of light. That beam can be broken up into infinitely many point sources, each of which results in an interference pattern.
But, I have absolutely no idea how to approach this question. I guess I want to find the wavelength that would have resulted in fringe center separation of 3mm and then compare it to 633nm (maybe get slope out of that). But I don't know how. :S Any hint would be greatly appreciated.
First, let's define some variables:
- y is the distance from the mirror's surface to the plane of constant phase
- m is the order of the fringe (1, 2, 3, etc.)
- λ is the wavelength of the light (633nm in this case)
- d is the distance between neighboring fringes (3mm in this case)
- θ is the angle between the line connecting A and B and the surface of the mirror
We can then use the equation y=m(λ)/2 to calculate the distance between the plane of constant phase and each fringe. Since the distance between neighboring fringes is d, we can set up the following equation:
y(m+1) - ym = d
Substituting in the equation for y, we get:
m(λ)/2 + (λ)/2 - m(λ)/2 = d
Simplifying, we get:
(λ)/2 = d
Now, we can use the small angle approximation to say that θ is approximately equal to y/d. We can then rearrange the equation to solve for y:
y = θd
Since we want to find the slope of the line between A and B with respect to the plane of constant phase, we can take the derivative of y with respect to θ:
dy/dθ = d
This means that the slope of the line between A and B on the uneven mirror's surface with respect to the plane of constant phase is simply equal to the distance between neighboring fringes (3mm in this case).
I hope this helps! Let me know if you have any further questions.
1. What is a Michelson Interferometer?
A Michelson Interferometer is a scientific instrument used to measure small distances, such as the wavelength of light. It works by splitting a beam of light into two beams, reflecting them back and recombining them. The resulting interference pattern can be used to calculate the distance between two surfaces.
2. How does a Michelson Interferometer work?
The Michelson Interferometer works by splitting a beam of light using a partially silvered mirror. One beam travels to a fixed mirror, while the other beam travels to a movable mirror. The two beams are then recombined and the resulting interference pattern is observed. By measuring the shift in the pattern when the movable mirror is moved, the distance between the two surfaces can be calculated.
3. What is the purpose of a Michelson Interferometer?
The main purpose of a Michelson Interferometer is to measure small distances, such as the wavelength of light. It is also used in various scientific experiments and research, such as studying the properties of materials or detecting gravitational waves.
4. What are the advantages of using a Michelson Interferometer?
One advantage of using a Michelson Interferometer is its high sensitivity. It can measure distances down to a fraction of the wavelength of light, making it useful for precise measurements. It is also a relatively simple and inexpensive instrument compared to other methods of measuring small distances.
5. Are there any limitations to using a Michelson Interferometer?
Yes, there are some limitations to using a Michelson Interferometer. It is only suitable for measuring small distances, and it requires a stable environment to produce accurate results. Additionally, it can only measure distances along the path of the light beam, making it unsuitable for measuring distances in other directions.
  • Atomic and Condensed Matter
  • Other Physics Topics
