Minimizing Volume with given equations and certain points. Calculus 32A
uclagal2012
A plane with equation xa+yb+zc=1 (a,b,c>0)
together with the positive coordinate planes forms a tetrahedron of volume V=16abc (as shown in the Figure below)
Find the plane that minimizes V if the plane is constrained to pass through a point P=(8,2,3) .
Here is a picture: https://www.pic.ucla.edu/webwork2_course_files/12F-MATH32A-1/tmp/gif/dhattman-1243-setSix-prob8--image_14_8_31.png
I used Lagrange multipliers SEVERAL TIMES.
I've gotten
Partial(a)=(1/6)bc G(a)=-8/a^2
Partial(b)=(1/6)ac G(b)=-2/b^2
Partial(c)=(1/6)ab G(c)=-3/c^2
I then found that a=4b, 2c=3b, and 3a=8c but I am SO STUCK after this. Please help!
1/(6abc), right?
I think that's right.
So you can write each of a, b, c in terms of some common parameter, substitute that into the equation for the plane, and express the fact that the plane goes through P.
I've gotten
The problem statement does not match the picture. To get the picture you need the equation of the plane to be
\frac{x}{a} + \frac{y}{b} + \frac{z}{c} = 1,
not what you wrote. Alternatively, you can use ##ax + by + cz = 1##, but the intercepts are 1/a, 1/b and 1/c, and the volume is 1/(6*a*b*c), as stated by haruspex. So first, you need to decide which representation you want to use.
You are correct in that it is supposed to be
Sorry, I am not used to this forum. Additionally, the V=1/(6*a*b*c)
So now are you able to help me more?
Sorry, I am not used to this forum. Additionally, the V=(1/6)(a*b*c)
You need to show your work, not just write down some unexplained equations containing undefined symbols (the G). Be explicit. What are the variables? What is the objective (the thing you are trying to maximize or minimize)? What are the constraints? (Here, I mean: write down all these objects explicitly as functions of your chosen variables.) We need to see all these things first, in order to know whether or not you are on the right track.
Assuming you have done the above, now write the Lagrangian, and then write the optimality conditions. Finally, there is the issue of solving those conditions, but again, let's see the conditions first in order to know whether you are making errors.
Judging from the OP, you correctly obtained the relationships between a, b, and c, except that it now appears you had each inverted in the definition. So go back to those equations and switch a to 1/a etc.
Then you're almost there. All you need to is what I wrote before:
Write each of a, b, c in terms of some common parameter (t, say), substitute that into the equation for the plane, and express the fact that the plane goes through P.
What parts of that do I need to explain more?
