Minimum distance between two vectors on a graph?
To calculate the minimum distance between two vectors with constant velocity, one can analyze the position difference vector as a function of time. This involves considering both the magnitude and direction of the vectors. Graphically, simply extending the position vectors may not adequately address the problem, as it doesn't factor in the rate of change of position over time. A more comprehensive approach is needed to accurately determine the minimum distance. Understanding the relationship between the vectors' slopes and their motion is crucial for solving this problem effectively.
dan.g117
This is just a theoretical question so there aren't any values for the variables but there are two vectors with constant velocity. Given their velocity, magnitude, direction how can one calculate the minimum distance between the two vectors.
Also have to solve graphically
I'm currently under the assumption it has to do with slope or something along those lines.
Input greatly appreciated.
http://img22.imageshack.us/my.php?image=examplehr3.jpg
thanks!
Welcome to PF.
Algebraically you can take the position difference vector as a function of time and determine the minimum.
Graphically ... just extending the line of action of position vectors doesn't seem to solve the problem you are asking about minimizing the position difference vector. A position graph alone doesn't really account for the rate of change of position as a function of time.
