Minimum stopping distance problem
In summary, to find the minimum stopping distance for a load of steel on a truck traveling at 20 m/s and held in place by metal brackets with a maximum horizontal force of 8000 N, you first need to find the acceleration in the negative x direction, which is -1.33. Then, using the equation v=vo+at, you can find that it takes 15 seconds to stop. Finally, using the equation x=xo+vot+.5at^2, the minimum stopping distance is calculated to be 150m.
Gashouse
A load of steel of mass 6000kg rests on the flatbed of a truck. It is held in place by metal brackets that can exert a maximum horizontal force of 8000 N. When the truck is traveling 20 m/s, what is the minimum stopping distance if the load is not to slide forward into the cab?
ok here how i did it,...im gettin an answer of 150m
first find the acceleration in the negative x direction the brackets can exert which is.
8000=(6000)a
a= -1.33
then find the time it takes to stop using v=vo +at
0= 20 + (-1.33) t t= 15sec
then find distance using x=xo +vot+.5at^2
x = 20(15) + .5(-1.33)(15)^2
x=150m
Thanks PN
Hey PHYSICS NOOB, I really appreciate the help. I worked the problem before coming on the forum and did'nt think that I was doing it correct. Thanks in advance again and for the fast response.
What is the minimum stopping distance problem?
The minimum stopping distance problem is a physics problem that seeks to determine the minimum distance a vehicle needs to come to a complete stop from a given initial speed. It takes into account factors such as the vehicle's speed, its mass, and the coefficient of friction of the road surface.
What are the key factors that affect the minimum stopping distance?
The key factors that affect the minimum stopping distance are the speed of the vehicle, the mass of the vehicle, and the coefficient of friction of the road surface. These factors can also be affected by external factors such as weather conditions and tire conditions.
How is the minimum stopping distance calculated?
The minimum stopping distance is calculated using the formula d = (v^2)/(2u), where d is the stopping distance, v is the initial velocity of the vehicle, and u is the coefficient of friction of the road surface. This formula assumes that the braking force is equal to the frictional force between the tires and the road surface.
What is the significance of the minimum stopping distance problem?
The minimum stopping distance problem is significant because it helps to determine the safe following distance between vehicles and the appropriate speed for different road conditions. It also highlights the importance of maintaining a safe and well-maintained vehicle, as well as the importance of adhering to speed limits and road regulations.
How can the minimum stopping distance be reduced?
The minimum stopping distance can be reduced by decreasing the initial speed of the vehicle, reducing the mass of the vehicle, and using tires with a higher coefficient of friction. Additionally, maintaining a safe following distance and being vigilant while driving can also help to reduce the minimum stopping distance.
