Mistake in proof regarding degeneracy property
HJ Farnsworth
Greetings,
I was trying to prove a theorem regarding degeneracy, and I succeeded. However, I also proved the converse of the if-then part of the theorem (underlined below), which I know is wrong. I can't spot my mistake though.
The theorem and my proof are written below - could someone please point out my mistake?
Theorem:
Let [A, B]=0 and let A|\alpha>=a|\alpha> (capital letters are operators, lowercase letters are scalars). If the eigenkets of A are not degenerate, then |\alpha> is also an eigenket of B.
Proof:
Using the given relations,
AB|\alpha>=BA|\alpha>=Ba|\alpha>=aB|\alpha>,
so that |\alpha> and B|\alpha> are both eigenkets of A with eigenvalue a.
CASE 1 - the theorem: Assume B|\alpha>\neqb|\alpha>. Then B|\alpha> is not writeable as a constant b times |\alpha>, so that |\alpha> and B|\alpha> are degenerate eigenkets of A. Therefore...
...If |\alpha> is not an eigenket of B, then the eigenkets of A are degenerate,
or equivalently,
...If the eigenkets of A are not degenerate, then |\alpha> is also an eigenket of B.
CASE 2 - the converse: Assume B|\alpha>=b|\alpha>. Then the eigenkets of A, |\alpha> and B|\alpha>, are the same except for multiplication by a constant, and so do not qualify as degenerate eigenkets of A. Therefore...
...If |\alpha> is an eigenket of B, then the eigenkets of A are not degenerate,
or equivalently,
...If the eigenkets of A are degenerate, then |\alpha> is not an eigenket of B.
The conclusion I reached in CASE 2 is just wrong. I can think of several examples where it is contradicted. For instance, letting A=J2 and B=Jz, eigenkets of A can be written as |j,mi>. These are degenerate eigenkets of A (one fore each -j\leqmi\leqj, and are simultaneous eigenkets of B.
What did I do wrong in CASE 2?
By the way, I am just looking for a description of my mistake, not a proof of something contradicting my conclusion (ie., I know the correct answer, I don't know what's wrong about my wrong answer). It's one of those obnoxious situations where I know proofs and examples that contradict my answer, but I'm not sure what the probably-obvious mistake I made in finding my answer is.
Actually, at the end of writing this post, it occurred to me that my mistake is probably that in CASE 2, I construct eigenkets of A using B and generalize my result to all eigenkets of A, which might not be constructible using B in this manner. I've already got the whole post written, though, so I may as well put it up. Could someone confirm, is that my mistake?
Thanks for any help you can give.
-HJ Farnsworth
Yeah, looks to me like the flaw is in case 2. There may be eigenkets of A which cannot be written as B|\alpha\rangle, so you can't prove that there is no degeneracy.
Great, thanks for the response.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
