Does Gravity Affect the Local Speed of Light in Accelerated Frames?
yogi
We start with a non accelerating long rocket having a clock C1 and photon source S at the front and a mirror M at the rear - photons are emitted at timed intervals recorded on C1 and their return is measured by C1 - so the round trip time for the rest frame is established. The rocket is then accelerated with uniform thrust and the experiment repeated - now the photon going from S to M will take less time than before and the reflected photon will take longer, both for the same reason as the one-way Sagnac effect. The difference in the time between the round trip with no acceleration and with acceleration can be used to determine the acceleration. Next, the rocket thrusters are turn off and the rocket is placed in a uniform G field that has the same intensity as the acceleration developed by the thrusters - the experiment is repeated - the equivalence principle predicts that the same time difference would be measured - but in the case of the rocket under thrust, the time difference was consequent to the fact that the photon traveled a different distance going and coming - in the G field the distance is the same - but the time should be equal to the result obtained when the rocket was accelerated. In both cases involving acceleration, the photon arrives back at the source at the same gravitational potential - so there is no change in frequency - so is the second experiment properly interpreted as an indication that the local velocity of light is affected by gravity?
How do you conclude that the distance is the same?
Mmx
have please a critical look at
arXiv.org > physics > physics/0609118
Physics, abstract
physics/0609118
Date: Thu, 14 Sep 2006 09:13:24 GMT (357kb)
Radar echo, Doppler Effect and Radar detection in the uniformly accelerated reference frame
The coordinate velocity of light is affected by gravity, but the local velocity of light is not.
If you use local rulers and local clocks, the speed of light locally is still 'c', as long as one uses a short enough distance.
I have to run now, there's probably more to say about this.
In the first case the rocket is an inertial frame and the total time t* over and back is 2L/c where L is the distance from the C1 to M. In the second case when the rocket is undergoing acceleration "a" the time t' from C1 to M is L/(c-at') and the return time t" from M to C1 is L/(c+at"). When the rocket is placed in a uniform gravitational field "g" where (g = a) should not the round trip time in the g field equal (t' + t") > t* as per what might be expected when the rocket was accelerated. And if the round trip time in the "g" filed is the same as in the "a" field, why do we not have an indication of the effect of g upon local light velocity. I welcome your correction.
Bernard - for some reason my acrobat reader cannot read your paper - I will try again
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
