Modeling coaxial cable impedance
To model the electrical equivalent of a coaxial cable, the user has data on conductor resistance, insulator resistance, partial discharge, insulation thickness, and overall diameter, but lacks inductance data. They initially planned to use a circuit with series inductance and resistance parallel to a capacitor but are unsure if this is the best approach. The discussion suggests using the Telegrapher's Equations for transmission line modeling, which may provide a more accurate representation. The user also inquires about when to use cascaded equivalents versus lumped or distributed models. Understanding these modeling techniques is crucial for accurately representing coaxial cable behavior.
student52
Hi,
I am trying to model electrical equivalent of a coaxial cable. The data I have is
1. Conductor resistance
2. Insulator resistance
3. Partial discharge
4. Insulation Thickness
5. Overall diameter
Actually I planned to use an equivalent circuit that has series connection of inductance and resistance parallel to a capacitor (Check the diagram shown below).Infact I am surprised to see quite different circuit here. With the data I have what circuit should I use? Kindly explain which of these circuits is apt.
--------inductance-------resistance-----
c
a
p
P.S. I don't have data about inductance
Thanks in advance,
Regards.
student52 said:
Hi,
5. Overall diameter
c
a
p
Thanks in advance,
Regards.
Welcome to the PF.
Transmission lines are generally modeled using the "Telegrapher's Equations" as described in this link:
http://en.wikipedia.org/wiki/Transmission_line
Are you wanting to model your coax differently?
Hi,
I wanted to know in what cases a cascaded equivalent should be used? I want to make sure in what cases should I use a lumped model and in which cases distributed model.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
