Modeling Path of Object in General Relativistic/Riemannian Geom
  • Thread starter Thread starter Philosophaie
    Path
Philosophaie
I want to use the Earth and/or Sun to model a General Relativistic or Riemannian Geometric path of an object with an initial velocity coming into a gravitational field until it comes into contact with the ground or skips off in another direction. Does anyone have any suggestion where to start?
Start by writing down the Schwarzschid metric for a spherically symmetric, nonrotating body:
<br /> ds^2 = -\left( 1 - \frac{2GM}{r} \right) \textrm{d} t^2 + \left( 1 - \frac{2GM}{r} \right)^{-1} \textrm{d} r^2 + r^2 ( \textrm{d} \theta^2 + \sin^2(\theta) \textrm{d} \varphi^2 ) \textrm{.}<br />
To get the geodesic equations from this, you can either calculate all the Christoffel symbols (long and tedious, but straightforward) or use the calculus of variations (my favorite method). In either case, I'd suggest setting e^{f(r)} = \left( 1 - \frac{2GM}{r} \right) for ease of notation. You'll end up with four very ugly-looking equations (one for each of t, r, \theta, and \varphi). By symmetry, you can set \theta = \frac{\pi}{2} (i.e., \theta&#039; = 0). The t equation will then give you e^{f(r)} t&#039; = E, where E is a constant of motion. The \varphi equation will give r^2 \varphi&#039; = L, where L is another constant of motion ("angular momentum"). The r equation gives
<br /> e^{-f(r)} (r&#039;)^2 + \frac{L^2}{r^2} - e^{-f(r)} E^2 = \epsilon \textrm{,}<br />
where \epsilon is another consant of motion. For massive particles, you can set \epsilon = -1 without loss of generality (why?). Then you can rearrange the above equation to get
<br /> \frac{1}{2} (r&#039;)^2 + V(r) = \mathcal{E} \textrm{,}<br />
where V(r) = \frac{1}{2} \left(1 + \frac{L^2}{r^2} \right) e^{f(r)} is a "potential energy" and \mathcal{E} = \frac{1}{2} E^2 is a "total energy." This looks exactly like the form of a classical equation of motion, and you can analyze it using similar techniques. In particular, determining values for E, L, and r_{0} that lead to bounded or unbounded paths is straightforward.
The Schwarzschild metric is:
ds^{2}=-(1-2GM/r)dt^{2}+(1-2GM/r)^{-1}dr^{2}...
I already calculated Affinity (Torsion=0), Riemann Tensor and the Ricci Tensor from the metric. I got the four ugly looking equations from the diagonal of the Geodesic Equation. This is where I get stuck. I would like to have more than just \theta=\pi/2. Is there a solution or a set of solution to these four Geodesic Equations no matter how difficult for all \theta?
LaTeX Code: ds^{2}=-(1-2GM/r)dt^{2}+(1-2GM/r)^{-1}dr^{2} ...
Yeah...sorry about that. \facepalm
Due to spherical symmetry, you can always change coordinates so that \theta = \frac{\pi}{2}, \theta&#039; = 0. Briefly, this is because, since we have invariance under rotations, the "direction of angular momentum" is conserved, hence the motion of a particle must be planar. (More rigorously, to each Killing vector on a manifold we can associate a constant of geodesic motion. The timelike Killing vector of Schwarzschild yields conservation of "energy," while the three spherical Killing vectors yield conservation of the three components of the "angular momentum.")
I don't know of any analytical solutions to these equations, except for very special cases. Like I said, however, they're (fairly) straightforward to analyze nonetheless; for example, you can derive, without too much work, the rate of precession of the perihelion of a planet using perturbation theory (to a first approximation). You should get \Delta \varphi = \frac{6 \pi G^2 M^2}{L^2}, where \Delta \varphi indicates the amount the perihelion advances per orbital period.
Thanks for the info!
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
