Modeling Sandwich Composites in Workbench: Non-Penalty Based Contact?
Modeling honeycomb composite structures in Workbench involves using solid tetrahedral elements for the core and isotropic shell elements for the aluminum face sheets, based on manufacturer data for stiffness. While this method yields accurate stress results for simple problems, the deflections are significantly off. There is a concern about penetration issues between the face sheet and core, prompting a discussion on whether to utilize non-penalty based contact methods. Suggestions include exploring coupling techniques (CP) for improved results. Overall, the conversation emphasizes the challenges of accurately modeling sandwich composites without incurring additional costs for specialized software.
BlkHwkEng
When I model a honeycomb type composite in workbench I tired modeling the core material as an orthogonal material type using solid tet elements and the aluminum face sheets as isotropic shell elements. I base the core material properties off of the honeycomb manufactures data for stiffness. using this approach I am able to get fairly accurate stress results when compared to hand calculations of the same simple problems (i.e. simple beam with distributed loading) but my deflections are completely wrong. I was hoping someone could give me insight on how to go about modeling sandwich composites in workbench...hopefully without paying another 50k for some type of composites modeler. Also I am getting a little better at APDL so if anyone wants to give advice based upon it I would be all ears.
Also I get tons of penetration between the face sheet and core material, should I use a non-penalty based contact or will this mess things up even more.
I hope this post makes sense...it is very late here and I am about to fall asleep on my keyboard.
Rather than using contact elements, perhaps you could try coupling them (CP)?
Way better results doing in like that. Thanks again minger
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
