How Is Drag Calculated on a Sphere in a Non-Uniform Flow Channel?
The discussion centers on calculating the drag force on a sphere in a microfluidic channel with a parabolic velocity profile, specifically under laminar flow conditions where Re is much less than 1. The challenge arises from the non-uniform flow, which complicates the use of standard drag coefficient data that assumes uniform flow. Participants agree that if the sphere is positioned off-center, the varying shear stress could indeed impart spin to the sphere, contrary to the assumption of symmetry when placed at the center. The need for simulation software to model these conditions is suggested for more accurate analysis. Overall, the conversation highlights the complexities of drag calculations in non-uniform flow scenarios.
Red_CCF
Hi
This isn't a homework question, just a problem I thought up of but would require some implementation I don't really know how to do.
If I have a microfluidic channel with laminar flow and a parabolic velocity profile as predicted in the Hagen-Poiseuille flow, and I insert into the channel a sphere of diameter 1/16th of that of the channel (can be anything really just something that's small but not negligible compared to the diameter), how would I calculate the initial drag force on the sphere assuming that Re<<1 such that there is no wake/flow separation?
The main problem here is that the velocity profile or uinf is not uniform, which means that all of the Cd data available is pretty much useless as they all assume uniform incoming flow.
I'm also wondering how the linear shear profile of the flow is reflected in the drag of the sphere since for a uniform incoming flow, there is no inherent shear stress in the flow. Also, would the varying incoming velocity cause the sphere to spin as well?
Re = UD/v, v = 1/4μ * (r^2-R^2) * dp/dz
Thanks
Sorry you're not getting any responses.
About all I can do is suggest that, by symmetry, there would not be spin imparted to your sphere. The only asymmetry would be gravity, so if you ignore that, I see no asymmetry in the fluid flow past the sphere, complex though it be.
Hi
I believe that to be true if the sphere was placed at the center of the pipe, but if I place it say a quarter diameter from the wall of the pipe, the dv/dr would not be zero and if the flow velocity past the sphere is different intuitively I would think the shear stress would also be different, hence why I think there would be a spin. Is this deduction correct?
Thanks
Red_CCF said:
Hi
Thanks
Afraid you're right. I assumed center position for the sphere.
I'd try to find some good simulation software! Sorry I'm not of more help.
I also agree there would in the off-center case be spin unless viscosity = 0.
