casualguitar
- Messages
- 503
- Reaction score
- 26
Updating on an initial attempt to reformulate the sharp front model on a mole basis:
Converting their capture step sharp front equations to a mole basis -
Component mass balance for defrost front:
\begin{equation}
\Phi'_1 \omega'_{i1} = \Phi'_2 \omega'_{i2} + A m'_i v_d
\end{equation}
##\Phi'_1## and ##\Phi'_2## are the molar flow rates after and before the defrost front, respectively (in moles per second), ##\omega'_{i1}## and ##\omega'_{i2}## are the molar fractions of component 'i' after and before the defrost front, respectively. ##A## is the cross-sectional area of the bed through which the gas flows (in square meters). ##m_i## is the number of moles of component 'i' deposited per unit of bed volume (in moles per cubic meter). ##v_d## is the velocity of the defrost front (in meters per second), calculated as the distance the defrost front travels divided by the time taken.
Component mole balance for frost front:
\begin{equation}
\Phi'_0 \omega'_{i0} = \Phi'_1 \omega'_{i1} + A m'_i v_f
\end{equation}
So we can see here that the molar flow out of the defrost front is equal to the molar flow into the frost front.
The frost and defrost front velocities dont change for our model. I am guessing that we will use the ##\Delta z## value to track the position of the front:
\begin{equation}
v_d = \frac{z_{d,2} - z_{d,1}}{\Delta t}
\end{equation}
\begin{equation}
v_f= \frac{z_{f,2} - z_{f,1}}{\Delta t}
\end{equation}
Energy balances on a mole basis:
\begin{equation}
A_{vd} \left[ \rho_s C_{p,s}' (T_2 - T_1) + m_i' \Delta H' \right] = \Phi_2' (T_2 - T_1) \left( \omega_{i2}' C_{p,i}' + \omega_{j2}' C_{p,j}' \right)
\end{equation}
\begin{equation}
A_{vf} \left[ \rho_s C_{p,s}' (T_1 - T_0) - m_i' \Delta H' \right] = \Phi_0' (T_1 - T_0) \left( \omega_{i0}' C_{p,i}' + \omega_{j0}' C_{p,j}' \right)
\end{equation}
where the heat capacities are in ##J/mol.K##
Overall mole balance for each front:
\begin{equation}
\end{equation}
\begin{equation}
\Phi'_0 = \Phi'_1 + A m'_i v_f
\end{equation}
We also have the molar desublimation rate equation which might be useful to calculate $m_i$:
\begin{equation}
M_i'' = k_i\frac{Py_i - p_T}{RT}
\end{equation}
Just one question - have I missed a relation here? It looks like we have 7 equations and 8 unknowns. I'm defining the unknowns as: ##T##, the molar fluxes out of the fronts ##\Phi_0## and ##\Phi_1##, the mole fractions out of the fronts ##\omega_0## and ##\omega_1##, the front velocities ##v_d## and ##v_f##, and the amount of solid buildup ##m_i## in mol/m3.
If this is not the intended reformulation just let me know and I can reform these equations
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
