Modelling of two phase flow in packed bed using conservation equations
454 replies · 39K views
Chestermiller said:
Yes. That is what I am asking for.
Result:
Is this correct?
So what I take from the above is:
1) We've got the enthalpy in terms of upwind mass flux and enthalpy values
2) We've also combined the mass and heat balances into one (removing the density derivative)
Also, is it correct to say we haven't really made any assumptions yet in terms of:
1) where saturation will occur (one temperature or a range)
2) which parameters are constant (none assumed constant yet)
So this equation is general enough to be used for a range of future models? i.e. the boiling range and non-constant parameter models?
EDIT: Whoops just noticing I left out the last term. Let me fix it
Fixed it. I had just forgotten to add the final term back in:
casualguitar said:
Result:
Is this correct?
You're missing a factor of ##\rho_x## on the LHS.
Yes, but we're still going to need to use the mass balance equation...to be discussed soon
Yes.
probably
Please compare this new version of the heat balance equation with the single tank lumped model we developed previously.
Isn't it past your bedtime? Don't you ever sleep?
Do you really play guitar? I play blues keyboard.
Chestermiller said:
You're missing a factor of ρx on the LHS.
Third time lucky:
Got it
To clarify, compare with post #38?
On occasion I do. Doing a PhD mostly from home (so far) is tough because any small thing that could have been answered by a postdoc/other research student in the lab as a throwaway comment turns into hours (or days) of me trying to figure it out myself (I will never underestimate the usefulness of a lab environment again once life returns to normal). So yes I value progressing this conversation, and conversations like this, more than sleep! It is bedtime now though
I do play. Mostly fingerstyle guitar covers of well known songs like this if you're interested:
I haven't had a chance to post in months although I am learning jingle bells currently. Hopefully in time for christmas!
Do you play music from any musicians in particular?
casualguitar said:
Third time lucky:
Got it
No. Post #57
I assume you have an advisor. We've covered a lot of ground so far, and you need to run all this by him/her so that they can be brought up to date and have an opportunity to comment. If you are going to do this using the approach that we've gravitated to, you need to get their sign-off on it. Otherwise, you could face big trouble later.
Enjoyed your performance. Was this by ear or from sheet music?
I used to be in a ballroom dance band, playing for cotillions, dancing school events, and weddings. We did fox trots, jitterbug, waltz, rumba, cha cha, salsa, tango, meringue, samba. But I'm no longer involved in such because the rehearsal took up too much time and we basically got paid very little (not that that mattered). In addition, I've developed Parkinson's starting 18 months ago, so my dexterity and balance have deteriorated. I could no longer carry all that heavy equipment (keyboard, speaker, music stand, piano seat, electrical wiring) and get everything connected with dexterity; plus my playing has deteriorated because of erosion of my motor skills. It really sucks. Even typing this is difficult.
Chestermiller said:
No. Post #57
Got it. Oh that's interesting, they're extremely similar. I know exactly what you mean now by 'series of stirred tanks'. We've converted the single tank lumped model into a series of stirred tanks model by essentially replacing the ##{m}_{in}## and ##h_{in}## terms we had in the single tank lumped model with the flux/enthalpy to each of the 'sub tanks' I suppose you could call them. Basically we're updating enthalpy and mass flux for each cell rather than taxing the initial values. I think this is simply equivalent to saying we are now considering space as a variable that affects flux and enthalpy, when previously we were not
I do have an advisor and I can confirm that I will be getting sign off on this progress this week. He won't mind about the general modelling approach taken, but will have comments on the required functionality of the model absolutely. It won't be a problem getting approval on this
Sheet music. Most stuff I play is broadly similar to that. At the start of Covid I played constantly and improved a lot. Now I only play on occasion. That cover was arranged by Kent Nishimura, who is probably my favourite guitarist right now (if you're interested have a look at his YouTube channel, there are songs spanning a broad range of genres/decades)
Very cool. I would imagine playing in a band is a lot more enjoyable than solo play! I'd love to play with a band. Sorry to hear about your Parkinson's. I would guess playing piano actually could actually help with Parkinson's though? In terms of maintaining dexterity/motor skills? Ever consider a piano YouTube channel?
If we multiply the finite difference versions of the mass balance equation and energy balance equation for the fluid by ##A_C\epsilon\Delta x##, where ##A_C## is the overall cross sectional are of the bed, we obtain :$$\frac{m_j}{dt}=\dot{m}_{j-1}-\dot{m}_j\tag{1}$$and $$m_j\frac{dh_j}{dt}=\dot{m}_{j-1}(h_{j-1}-h_j)+UA_j(T_{S,j}-T_j)\tag{2}$$where the subscript j refers to the j'th tank, ##m_j=\rho_jA_C\epsilon \Delta x=\rho_j(V/n)## is the mass of fluid in the j'th tank, V is the total pore volume of the bed, n is the total number of tanks (grid spaces) in the bed, ##\dot{m_j}=\phi_{x+\Delta x/2}A_C\epsilon## is the mass rate of fluid flow exiting the j'th tank, and ##A_j=A/n## is the heat transfer area in the j'th tank (equal to the total heat transfer area in the bed A divided by the number of tanks).
Similarly, if we multiply our energy balance on the bed by ##A_C(1-\epsilon)\Delta x##, we obtain
$$m_{S,j}C_{PS}\frac{dT_{S,j}}{dt}=UA_j(T_j-T_{S,j})\tag{3}$$ where ##m_{S,j}=\rho_S A_C(1-\epsilon)\Delta x=M_S/n## is the mass of solid packing in the j'th tank and ##M_S## is the total mass of solid in the bed.
We can find the rate of fluid flow exiting the j'th tank (and entering the (j_1)'th tank) by rearranging Eqn. 1 to read: $$\dot{m}_j=\dot{m}_{j-1}-\frac{dm_j}{dt}\tag{4a}$$with $$\frac{dm_j}{dt}=\frac{V}{n}\frac{d\rho_j}{dt}=\frac{V}{n}\left(\frac{d\rho}{dh}\right)_j\frac{dh_j}{dt}\tag{4b}$$
Chestermiller said:
If we multiply the finite difference versions of the mass balance equation and energy balance equation for the fluid by ACϵΔx, where AC is the overall cross sectional are of the bed, we obtain :(1)mjdt=m˙j−1−m˙jand (2)mjdhjdt=m˙j−1(hj−1−hj)+UAj(TS,j−Tj)where the subscript j refers to the j'th tank, mj=ρjACϵΔx=ρj(V/n) is the mass of fluid in the j'th tank, V is the total pore volume of the bed, n is the total number of tanks (grid spaces) in the bed, mj˙=ϕx+Δx/2ACϵ is the mass rate of fluid flow exiting the j'th tank, and Aj=A/n is the heat transfer area in the j'th tank (equal to the total heat transfer area in the bed A divided by the number of tanks).
Similarly, if we multiply our energy balance on the bed by AC(1−ϵ)Δx, we obtain
(3)mS,jCPSdTS,jdt=UAj(Tj−TS,j) where mS,j=ρSAC(1−ϵ)Δx=MS/n is the mass of solid packing in the j'th tank and MS is the total mass of solid in the bed.
I follow this much exactly. Makes perfect sense
Chestermiller said:
We can find the rate of fluid flow exiting the j'th tank (and entering the (j_1)'th tank) by rearranging Eqn. 1 to read: ##m˙j=m˙j−1−\frac{dm_j}{dt}## with ##\frac{dm_j}{dt}=\frac{V}{n}\frac{d\rho_j}{dt}=\frac{V}{n}\left(\frac{d\rho}{dh}\right)_j\frac{dh_j}{dt}\tag{4b}##
I follow the maths here also.
So the flow of calculations here may be:
1) ##4b## supplies ##4a## with ##\frac{dm_j}{dt}##
2) ##4a## calculates ##\dot{m}_j##
3) ##4a## supplies ##\dot{m}_j## to equation ##2##
4) Then we're at the point of having all required inputs for eq ##2## and ##3## which can then be solved
5) The new ##\frac{dh_j}{dt}## value can be subbed into ##4b## to repeat the cycle
However, I've skipped over the ##\frac{d\rho}{dh}## term here, which we don't have an equation for.
Guess for model progression from here:
Equation ##4b## does have a ##\frac{dh_j}{dt}## term in it though which means we could probably use equation two to help solve for ##\frac{d\rho}{dh}##. So my guess here would be that we won't need a relation for ##\frac{d\rho}{dh}##, instead we will have something like ##3## equations solving ##3## unknowns, rather than two equations and two unknowns like usual?
Edit: Also, I'm working on that 'documentation of the work so far' powerpoint now. What exactly we've done from the start is a bit hazy for me, so I think it will be interesting to see
Edit 2: Also out of curiosity what musicians do you play/listen to? Always looking for new music to listen to/play
The primary objective is: knowing the values h, ##\rho##, T, and ##T_S## in each of the tanks, getting the time derivatives of h and ##T_S## in each of the tanks. Understand that, in the previous lumped model, we had expressed both ##\rho## and T as physical property functions of h for each of the three enthalpy regions (liquid, saturated liquid-vapor mixture, and vapor). We use these exact same physical property relationships in this model. This allows us to determine ##d\rho/dh## for any tank in the sequence.
The computational flow goes like this:
1. Focus first on the 1st tank
2. We know ##\dot{m}_0## because this the mass flow rate into the bed.
3. Use Eqn. 2 to get ##dh_1/dt##
4. Use Eqn. 4b to get ##dm_1/dt##
5. Use Eqn. 4a to get ##\dot{m}_1## (the mass flow rate from tank 1 into tank 2)
6. Use Eqn. 3 to get ##dT_{S,1}/dt##
Repeat steps 3-6 for each subsequent tank until we have the time derivatives of h in all the tanks. Eqns. 4 tell us the mass flow rate into each subsequent tank (for use in Eqn. 2).
I have a recommendation. Get some practice applying Eqns. 4 by using the lumped model to determine the mass flow rate out of the tank as a function of time. (We didn't do this in the lumped model so far because it was not needed.). See if you can make a graph of this (of course using a semilog scale for the mass flow rate out).
Blues musicians I like: B.B. King, Dr. John, Professor Longhair, John Lee Hooker, Pine Top Smith, Pine Top Perkins, Daryl Davis, Muddy Waters, Elmore James, Stevie Ray Vaughn, Katie Webster, Susan Tedeschi
Chestermiller said:
We use these exact same physical property relationships in this model. This allows us to determine dρ/dh for any tank in the sequence.
Got it. I think I follow everything there except the above line. I'm not sure of we can get ##d\rho/dh##
So the relationships from post #62 give ##\rho(H)## and ##T(H)##:
If ##h\leq 0## then:
$$T=T_{sat}+h/C_{PL}$$
$$m=\rho_L V$$
If ##0\leq h \leq \Delta h_{vap}## then:
$$T=T_{sat}$$
$$m=\frac{V}{\left[\frac{1}{\rho_L}+\left(\frac{RT_{sat}}{PM}-\frac{1}{\rho_L}\right)\left(\frac{h}{\Delta h_{vap}}\right)\right]}$$
If ##\Delta h_{vap}\leq h## then:
$$T=T_{sat}+(h-\Delta h_{vap})/C_{PV}$$
$$m=\frac{PM}{RT} V$$
Chestermiller said:
4. Use Eqn. 4b to get dm_1/dt
So for this calculation we need ##d\rho/dh##. Looking at the above equations, I can see that it will be 0 for the liquid phase because m is not a function of T. However for the other two cases we will need to know how to calculate ##d\rho/dh##. It is as simple as:
$$\frac{d\rho}{dh} = \frac{d\rho_j - d\rho_{j-1}}{h_j - h_{j-1}}$$
We would have the ##j-1## terms from the previous iteration, and we would have ##h_j## and ##h_{j-1}##. We're just missing ##\rho_j## then which we would calculate with your ##\rho(h)## correlations
Does that look right?
I'll do this yes, I'd like to finish talking about this model (and I'll try write out a full model flow) first and then I'll start modelling with your recommendation
Oh interesting, I'll be honest the only musicians I know here are B.B. King and SRV (big fan of both, because of the guitar playing). I have never heard of any of the others. I guess I'll recognise songs if they're well known, but I'm not aware of any of them anyway. Might as well throw them on Spotify as background music for the day then!
$$T=T_{sat}$$
$$m=\frac{PM}{RT} V$$So for this calculation we need ##d\rho/dh##. Looking at the above equations, I can see that it will be 0 for the liquid phase because m is not a function of T. However for the other two cases we will need to know how to calculate ##d\rho/dh##. It is as simple as:
No. The derivative is evaluated analytically for the same tank, with no reference to adjacent tanks. For the liquid/vapor region, the density is $$\rho=\frac{1}{\left[\frac{1}{\rho_L}+\left(\frac{RT_{sat}}{PM}-\frac{1}{\rho_L}\right)\left(\frac{h}{\Delta h_{vap}}\right)\right]}$$So you just differentiate this analytically with respect to h. Similarly for the pure vapor region.
Ah nice I see, got it. These are the results I got for the derivatives:
The negative sign shows the density will decrease with increasing enthalpy which is what we want I think i.e. more vapour = lower density
I think you have already laid out the full flow of calculations in post #129, but I'm going to read back through to be sure I follow the flow. So if we choose ##T_sat## and ##\Delta h_{vap}##, we're at the point of being able to model this it looks like?
It looks quite a bit more difficult to model than the previous models. So I'm going to avoid trying to model this, until I've implemented your recommendation above
That's not what I get when I differentiate. For the liquid/vapor region, I get:$$\frac{d\rho}{dh}=-\rho^2\frac{\left(\frac{RT_{sat}}{PM}-\frac{1}{\rho_L}\right)}{\Delta h_{vap}}$$
and for the pure vapor region, I get:$$\frac{d\rho}{dh}=-\frac{PM}{C_{PV}RT^2}=-\frac{\rho}{C_{PV}T}$$I guess the latter is equivalent to what you had, but it's a much more compact form.
Hmm I see your solution for the liquid/vapour region has ##\rho## in it rather than ##h##. What relation are you using to replace ##h## with ##\rho##?
I use the original equation for ##\rho##. $$1/denom^2=\rho^2$$
In particular, if $$\rho=\frac{1}{D}$$the$$\frac{d\rho}{dh}=-\frac{1}{D^2}\frac{dD}{dh}=-\rho^2\frac{dD}{dh}$$
Ahh I follow now. Why is it advantageous to sub ##\rho## back in though? Less code I guess, given that we'll already have an existing density function?
I'll summarise everything you've said on this model in the next comment
2. We know m˙0 because this the mass flow rate into the bed.
3. Use Eqn. 2 to get dh1/dt
4. Use Eqn. 4b to get dm1/dt
5. Use Eqn. 4a to get m˙1 (the mass flow rate from tank 1 into tank 2)
6. Use Eqn. 3 to get dTS,1/dt
Yep I have effectively nothing to add to this summary, other than we will need to calculate ##\frac{d\rho}{dh}## before \frac{d_{m1}}{dt}, which we can do with your liquid/vapour/liquid-vapour enthalpy density/temperature equations
I guess I'll still need equations 2 and 3 here? Or are you describing a simpler model?
So the idea would be to not calculate mass flow/enthalpy at each point, but assume it is constant throughout the vessel (as we did previously). Then we can use the mass equations to calculate the hold-up mass and the mass flow out at any time?
Once you know h at all the grid cells, you also know ##\rho## and T. And, once you know those, you also know ##d\rho/dt##
casualguitar said:
Yep I have effectively nothing to add to this summary, other than we will need to calculate ##\frac{d\rho}{dh}## before \frac{d_{m1}}{dt}, which we can do with your liquid/vapour/liquid-vapour enthalpy density/temperature equationsI guess I'll still need equations 2 and 3 here? Or are you describing a simpler model?
yes. All you are doing is adding output to what you already have from the lumped model. Nothing about the model itself changes. We are just looking at one additional output parameter from the model.
Just a passing thought for now, but if we know h and T (and P), then I think this would be enough to calculate x (quality) in future models, for pure fluids. Assuming we have real correlations for the vapour and liquid enthalpies, we could use the quality equation #h = xh_l + (1-x)h_v
Ahh I see. I was about to overcomplicate. So essentially we know the inlet mass flow is constant, and I'm just tracking the holdup mass over time. Then ##m_{out} = m_{in} - m_{holdup}##. Should be easy to add in
We are going to do all this off-line. We've going to look at the functionality of T and rho as functions of h, and develop algebraic fits to this.
No. We want to know ##\dot{m}## out of the tank, not the total mass in and out. We want to get practice calculating this directly from Eqns. 4, since that is what we will need for each tank in the multi-tank model. In the single tank model, it is strictly an output, not required to make the actual calculation.
My apologies for the questions on this, but what does this line mean?
You're saying for this mass flow out calculation I do much calculations, such as set up a function for ##\frac{d\rho}{dh}##?
Or are you saying I should set this function up, use the ##\frac{d\h}{dt}## results from the previous single tank model, calculate results to eq. 4b using the newly calculated ##\frac{d\rho}{dh}## array and the old model ##\frac{d\h}{dt}## array results, and then use 4b output as 4a input, then graph 4a as a function of time?
Yes. That is exactly what I mean. Just calculate it from the old model results.
Ah I see, understood. Will get on this tomorrow morning 👍
Working on this. Having an issue extracting the dh/dt values into an array. The rest of the calculation is done though so this should be the only roadblock
What’s the problem? You are already calculating dh/dt at each time step.
Exactly I have. I'm extracting the dh/dt value at each time interval which is giving an array of length 196, rather than the expected length of 4000. The mass holdup, dp/dh, and temperature arrays are all length 4000. I'm working on debugging currently
Are you saying you store the results in an output array and write the array to an output file after you are done? If so, why aren't you just writing the results to an output file at each time step?
