Modelling of two phase flow in packed bed using conservation equations
454 replies · 42K views
Chestermiller said:
Do you know how to solve this analytically (two linear coupled ODEs in two unknowns)?
I don't. I can figure this out though. So to confirm, the two equations are the solid and energy balance here:
Where ##h## and ##T_s## are the two unknowns, and where the ##h<=0## correlations will be used for ##T## and ##m##?
Yes, the liquid region, and, for the analytic solution, you can use the constant heat capacity version of the equations. You are taking V as the pore volume, right? What values of the parameters are you using:
Mass of liquid in bed
Mass of solid bed
Mass flow rate of liquid to bed
U, A,
Heat capacity of solid
Heat capacity of liquid
I've done part of the analysis (but I want you to also do it), and I've got equations for the time constant(s) in terms of the above parameters. This should tell us much more about the long time response.
Mass of solid bed
U, A,
Understood, so these equations, for the liquid phase i.e. T<Tsat:
Yes V is the pore volume for this model
Parameter Values:
Mass of liquid in bed = 8kg
Mass of solid in bed = 1kg
Mass flow rate of liquid to bed = 0.05kg/s
U = 1 W/m2K
A = 0.1m2
Heat capacity of solid = 1.1 kJ/kg.K
Heat capacity of liquid = 2 kJ/kg.K
In regards to the analytical solution, what makes up an analytical solution in this case?
Are we talking about solving for the eigenvalues, or do we mean solving the linear system, i.e. to get h(t) and Ts(t)?
The general approach I was planning to take here is:
1) Differentiate one of the energy balances w.r.t. time to get the second derivative
2) Substitute the other equation in
3) Solve the first equation for h (or Ts)
4) Substitute h (or Ts) back into the second derivative equation
5) We'll get the characteristic equation from this as we'll have the second and first derivative of h, and h
6) then assuming ##\lambda_1## and ##\lambda_2## are the roots
$$h(t) = c_{1}e^{\lambda_1t} + c_{2}e^{\lambda_2t}$$
$$Ts(t) = c_{3}e^{\lambda_1t} + c_{4}e^{\lambda_2t}$$
Where c1-c4 come from h(0), Ts(0), h'(0) and Ts'(0). If this is the route we're going then one question I would have is what would the values of h'(0) and Ts'(0) be?
I’m having a medical issue presently, and am not going to be able to participate as much as I’d like to for a while. It is very frustrating because I have lots that I’d like to cover with you.
For the analytic solution, I would work with T and TS, and work with a matrix formulation, starting with subtracting out the final steady state temperatures equal to Tin.
Absolutely, take the time needed to recover from this, please! Sorry to hear this. Forget about me I'll be fine!
I can and will do this analytic solution using a matrix formulation. I guess the next step would be to check if it matches the model and if not figure out why it does not match. Plenty to work on!
Thanks Chet for everything so far. It is hugely appreciated. And take your time with the recovery!
Parameter Values:
How come the mass of solid packing is less than the mass of liquid in the bed? Isn't the density of the solid higher, and isn't there more volume fraction packing?
And, if I recall correctly, previously, wasn't the mass flow rate of fluid.
Hi Chet, hope your medical issue is going well. As I say absolutely zero pressure to respond here! I can work away
The solid mass is less than the liquid mass because I suppose I only needed to define the pore volume in the code, not the overall volume of the tank. The total tank volume is not defined. I can do this now though to get a more reasonable value for solid mass
Taking a pore fraction of say 0.3, the tank total volume would be ##0.01*10/3 = 0.033m^3##, where ##0.01m^3## is the pore volume.
Liquid mass = ##0.033*0.3*800 = 8kg##, where ##800kg/m^3## is the liquid density
Solid mass = ##0.033*0.7*2500 = 57.75kg##, where ##2500kg/m^2## is the solid density
I'll sub in the new solid mass value now
I assume this is a typo, and you're asking about previous mass flow rate values. I did use ##0.01kg/s## in the original ##dT/dt## model. This value was changed to ##0.05kg/s## for no particular reason (I was likely changing the flow to get a nicer plot), and is now ##0.05kg/s## in all models
In the present version of the multi-tank model, the balance equations read: $$\dot{m}_{i}=\dot{m}_{i-1}-\frac{V}{n}\frac{d\rho_i}{dt}$$$$\frac{V}{n}\rho_i\frac{dh_i}{dt}=\dot{m}_{i-1}(h_{i-1}-h_i)+U\frac{A}{n}(T_{S,i}-T_i)$$and$$\frac{m_s}{n}\frac{dT_{S,i}}{dt}=-U\frac{A}{n}(T_{S,i}-T_i)$$where V is the total pore volume in the bed and A is the total heat transfer area in the bed.
If we multiply all three of these equations by the number of tanks n, we obtain:$$\dot{M}_{i}=\dot{M}_{i-1}-V\frac{d\rho_i}{dt}$$$$(V\rho_i)\frac{dh_i}{dt}=\dot{M}_{i-1}(h_{i-1}-h_i)+UA(T_{S,i}-T_i)$$and$$m_s\frac{dT_{S,i}}{dt}=-UA(T_{S,i}-T_i)$$where $$\dot{M}_i=n\dot{m}_i$$These equations tell us that the multi-tank model is equivalent mathematically to a tanks-in-series-model in which each tank in the series is identical to the single tank model of the entire packed bed, but with the mass flow rate to the first tank in the series equal to n times the actual mass flow rate to the bed. This form of the model is much easier to code than the present version of the model because much of the code can be extracted from the single tank model (plus we don't have to divide everything by n), less error prone, and it is much easier to conceptualize. What do you think?
I follow the reasoning almost completely except the mass flow point here is slightly confusing. So you say the multi-tank model is equivalent mathematically to a tanks in series model. I follow this. It means we can model each individual tank in the multi-tank model the same way the single tank is modeled. So essentially we'll have n single tank models in series, and this is equivalent to the multi-tank model.
This bit though - so we'll have the mass flow to the first tank actually equal to say 0.05kg/s, however we want to multiply this value by n. So capital ##M## is not really the mass flow, its a kind of total flow through the system value. So we will be solving for capital ##M## at all spatial points in the system, and to find the mass flow array we would just need to divide by n? This would make sense to me. Does this M term have physical significance?
I can code this model up. For this model as we're extracting code from the single tank model, I think it makes sense to finish the analytical solution for the liquid phase single tank model first. I'm actually working on the analytical solution currently. Then once its clear the numerical solution to the single tank checks out, I can use this code for the multi-tank modeled you've detailed above. How does this approach sound?
For the trick model, the ratio of the mass flow rate to the the total mass of packing or of fluid in the sequence of tanks must be preserved.
Understood. I fully follow. If there is an error in the single tank code this will probably happen in the multi-tank model also, so do you think its worth finishing out the analytical solution model/code first?
Definitely.
Chestermiller said:
Definitely.
On it. Thanks Chet
In regards to output from the analytical solution, I guess we are we looking for:
- A graph of fluid enthalpy vs time
- A graph of solid temperature versus time
To check if the timescale for the analytical solution matches that of the numerical one, for the liquid phase
casualguitar said:
On it. Thanks Chet
For outside presentation of the validation checks, I think it would be better to compare temperatures vs time.
Hi Chet, update on the analytical solution:
I haven't been able to actually derive the analytical solution myself yet (seems more difficult than I first anticipated), however Mathematica does this and has solved the equations both numerically and analytically. I'll transfer the analytical solution functions (if correct) to Python. Here is the output for fluid temperature versus time (I have the solid plot also, its basically the same):
You can see the constant values I used, plus the T(t) and Ts(t) analytical solution functions output by Mathematica (the functions are blurry so I've typed them out at the bottom), and also the analytical solution graph from 0 to 3000s. Note it seems to curve off unexpectedly just before 3000s.
Here is the numerical solution, also done by Mathematica. The plot starts out similar to the analytical one, and continues to level off towards the inlet temperature indefinitely, which seems to make more physical sense. There is no unusual decrease in temperature behaviour happening in the numerical solution
Its late here so I'm going to check these plots against my own code first thing tomorrow.
Edit: The screenshooting doesn't seem to want to cooperate with the Mathematica page so I'm copying the analytical solution below. It doesn't seem to want to wrap at the end of the line (its two equations in the same line), so I will edit this tomorrow
$${{T(t) = 90 -4.37526 E^{(-0.0133365 t)}-5.62474 E^{(-0.000737726 t)}-4.44089*10^{-16} E^{(0.0125987 t)}]
and
Ts(t) = 90 +0.585555 E^{(-0.0133365 t)}
+8.88178*10{^-16} E^{(-0.0125987 t)}-10.5856 E^{(-0.000737726 t)}
-8.88178*10^{-16} E^{(0.0125987 t)}]}}$$
I haven't been able to actually derive the analytical solution myself yet (seems more difficult than I first anticipated), however Mathematica does this and has solved the equations both numerically and analytically. I'll transfer the analytical solution functions (if correct) to Python. Here is the output for fluid temperature versus time (I have the solid plot also, its basically the same):View attachment 293819
and
Their analytic solution is very puzzling because there are only two eigenvalues to the characteristic equation. Here is the eigenvalue equation I came up with: $$\lambda^2+\left[\frac{\dot{m}_{in}}{m}+\frac{UA}{mC}+\frac{UA}{m_sC_s}\right]\lambda+\frac{\dot{m}_{in}}{m}\frac{UA}{m_sC_s}=0$$
For the parameter values you showed in your printout, this gives $$\lambda=-0.0133$$and$$\lambda=-0.000738$$which matches their values (at least on the two main terms). This implies a time constant at long times of 1/0.000738=1355 sec.
Let's see how your numerical solution compares to their analytic solution..
The analytical and numerical solutions from Mathematica now match. The problem was in how Mathematica deals with decimal numbers. So the graphs of T and Ts vs time now match.
And here is the analytical solution:
Editing my numerical solution now to compare.
There we go, my numerical solution does seem to match the Mathematica one:
And here is the plot for the liquid phase temperature, using the spatial variation model, assuming n=2 (so the inlet conditions plus one spatial point). Ignoring the jumps, This also matches the other plots:
Note the time is x1000 (due to 1000 points calculated per time step) so dividing the x-axis values by 1000 gives the same values as the previous plots
And lastly, I've set n = 32 and plotted the final position (index 31) versus time:
This also roughly matches the timescale of the other plots. Is this all reasonable to you?
And here is the plot for the liquid phase temperature, using the spatial variation plot, assuming n=2 (so the inlet conditions plus one spatial point). Ignoring the jumps, This also matches the other plots:
How about running the 3 tank version and plotting temperature vs time on the same graph for all three tanks? Don’t you expect a time delay between subsequent tank time responses as the wave travels through the bed?
Yes there seems to be a slight delay looking at the n=32 plot
Doing this now
Here we go, this is for n=4. I went with n=4 so we can see three inner-tank Tf vs t graphs, position 0 is just the inlet condition.
As you mentioned we can see the time delay across the tank. The plot is quite messy due to these 'numerical bumps'. The output does look similar to the analytical and numerical output from Mathematica though.
Reverting back to the two phase model (assuming liquid in the tank, with a gas 300K input). Heres the graph for n=4. This also seems to approximately matches the timescale of the others:
Am I correct in saying this means that the spatial variation model is correct? i.e. no particular need to move to the model you outlined yesterday? I will code this up anyway but it seems the original spatial variation model is ok?
What are the actual times on the time axis? Is 1 the same as 1000 seconds? If so, can you please show the results only up to the 1000 seconds part (so 1000 is the full horizontal range)? Also, can you please include the single tank model results for the entire bed for comparison? All this for the liquid only case. Thanks.
Yes correct
Can do, this is both graphs above, to 1000s, for the liquid phase only (90K inlet stream, bed initial temperature of 80K).
Single tank:
Spatial variation plot: for n=4:
The single tank plot seems to best match the first position here.
To clarify by this do you mean plot both the fluid and solid temperature for the single tank, for the liquid phase?
Note: Its just the spatial variation plot that is time*1000 for the x axis
casualguitar said:
Yes correct
Single tank:
The single tank plot seems to best match the first position here.To clarify by this do you mean plot both the fluid and solid temperature for the single tank, for the liquid phase?
Any chance of showing the single tank model results for the entire bed on the same plot as the multi-tank model results for this same case? Also show the single tank model for the entire bed with 3X the mass flow rate in?
I think so, I'm not exactly sure how to do that yet but yes
I can do this now. When you say 'entire bed' what do you mean here? As there is only one tank in the single tank model. Or do you mean plot each position for the n=4 model? For 3x flowrate
The former.
Chestermiller said:
The former.
Here we go, this is a 3x flowrate plot for the single tank model. So the flow here is 0.15kg/s. Everything else is the same:
I will look into this overlay plot now. There is almost definitely a convenient way to do this
This is what the first tank in the 3 tank model should give. Does it?
Hmm, this is the Mathematica analytical solution for 3x flowrate (zoomed to appropriate section because its fairly blurry otherwise):
Taking a reference point of 1000s, the temperature is just above 89, say 89.1K
Here is my numerical solution for the 3x flowrate single tank model (from above):
At t = 1000s, the temperature seems to be around 89K also, so its similar to the plot above. I think we can now say the Mathematica plot, and my single tank numerical solution are both correct
Multi-tank plots:
Here is the multi-tank plot for n=3, and m = 0.05kg/s:
At t = 1000s, the temperature is 88K, so its 1K lower than the single tank plots.
Am I correct to use n = 3 here?
Here is the plot for n= 4:
So t = 1000 and T = 88.3K or so. about 0.7K off.
I don't know if these are 'close enough' or not, but my guess is that they are not close enough. I'll run some diagnostics now in case it is not close enough
Multi-tank plots:
You need to compare the temperature vs time of the first tank in your multi-tank 3 tank model with the temperature vs time for the single tank model of the full bed, the latter at 3x the flow rate of the former. The two results should match exactly. I hope I’m making it clear what I’m asking for. This is a validation check on the multi-tank model.
The idea is clear, and I can validation check by using the values of the other parameters (h,m,Ts).
One question - I'm not clear on the correct value of n. My thoughts are that temperature is evaluated at the 'centre' of a tank. n=0 is at the inlet and n=n is at the outlet. So to have 3 'tanks', we would need n=5?
Either way none of n=3,4,5 give exactly the same solution as the analytical one, so I need to do some testing regardless
