How to Derive Differential Equations for a Second Order System?
To derive the differential equations for a second order system, the discussion emphasizes the importance of accurately applying Newton's second law, ΣF = ma. The user attempts to analyze the forces acting on mass m1, considering the spring force (k.x1) and the damping force (B.(x2dot - x1dot)). Clarification is provided that the spring and damper forces oppose the motion of mass m1. It is suggested to express the motion equation as m1.äx1 = -kx1 for clarity. Proper notation and understanding of forces are essential for deriving the correct differential equations.
MarkD88
I have attached an image of a question I am trying to do, I want to find the differential equations that describe the second order system in the image.
I know for a spring, potential energy = 1/2.K.x (where k is the spring constant, and x is the distance the spring is stretched).
I know that damper dissipation is = 1/2.B.(dx/dt) (where B is the damping constant and dx/dt is the rate of change of position with respect to time).
My solution:
I try to build a free body diagram for each mass on its own:
I have showed a snapshot of my attempt for the D.E. describing the motion of m1.
If any of you guys could tell me if I am correct or you have a handy way of doing these types of questions please feel free to respond.
Thank you
Hello Mark, welcome to PF :smile: !
For some reason the template has disappeared. Pity (*). The relevant equation is ##\Sigma F = ma##. So you want to sort out the signs a little more carefully (of the forces; ##-k## is not a force, nor is ##-B## ).(*) Its use is mandatory in PF, for very good reasons; see the guidelines.
Hi BvU,
Apologies about the template, I will not post without a template again.
My notation there was a little careless, I did not mean to label K and B as forces, I was trying to imply that there is a force acting on mass m1 due to both the spring and the damper.
Spring: k.x1
Damper: B.(x2dot-x1dot)
And that these two forces oppose the motion of mass m1 from left to right.
is good. And when you state that, you should also write something like ##m_1\ddot x_1 = -kx_1## and not e.g. ##m_1\ddot x_1 -kx_1 = 0 ## :rolleyes:
