Molar extinction coefficient calculation.
To calculate the molar extinction coefficient (ε) for albumin at 280nm, both absorbance (A) and concentration (c) are needed, but only the molecular mass of albumin is provided. The user is confused about how to find A, which is essential for determining ε. It is suggested that experimental data, such as absorbance measurements, is necessary to proceed, as theoretical calculations alone may not suffice. Additionally, the extinction coefficient can vary based on the protein's structure and amino acid composition, and online calculators may assist in estimating it. The user plans to seek clarification from a professor regarding the missing information needed for the calculation.
Lahe
I need to calculate molar extinction coefficient for Albumin at 280nm.
A=ε*c*L
ε=A/(c*L)
But since L=constant, I can just say ε=A/c
The given molecular mass of albumin is 66,5kDa, which equals 66500g/mol. I do understand that I can find c (concentration) via the molecular mass. What I don't understand is how can I find ε if I still have another unknown, which in this case happens to be A.
So: ε(unknown)=A(unknown)/c(known).
Have I missed something really simple and overthinking this for myself? How can I find Absorbance?
A=ε*c*L
ε=A/(c*L)
With an equation relating three things you need two to be able to determine the third.
"How can I find Absorbance?"
You measure it. Or someone else measured it and tells you. Or you know ε and c and calculate it.
We guess you know c. We cannot understand from your question what your problem is and what you are given or know but you are probably overlooking some information you have been given.
I need to calculate ε. In order to do that I need A and c. In this case, though, the only given information is that the molecular mass of albumin is 66,5kDa. I understand I need to know two things in order to determine the third, but I can't find a way to determine the first two in the first place.
Since I've been told to calculate ε I believe I need to know A and c. I do know c, but as of right now I am stuck with trying to determine A in order to calculate c.
Probably a typo as it makes no sense. Your question hardly does - who has asked you to do what and given you what information? There has to be an experimental datum, either a concentration or an absorbance somewhere. The extinction coeffeicient of bovine serum albumin can easily be found on the webv http://en.wikipedia.org/wiki/Bovine_serum_albumin
Determining the extinction coefficient of proteins without experimental data (an absorbance as a function of concentration curve) is not a trivial matter. The absorbance at 280nm buy proteins is due to, mainly, the aromatic side chain amino acids (Tyr, Trp, maybe Phe) under going electronic transitions of the pi system. Therefore the extinction coefficient will vary with size, primary structure, and conformation (due to interactions of the aromatic side chains with other species in the protein's native form). There are calculators out there which estimate the extinction coefficient based on the amino acid sequence, but an experimentally determined Abs([Pro]) curve is used most often.
Thanks for the feedback, I'll leave it undone as of this moment and talk this through with my prof tomorrow. The context of this question/exercise indeed is very "awkward" may I say so. Was searching the internet for hours about this. Positive side was that I found this forum, which I obviously also joined and I'm glad I did. I'll definitely stick around ;)
Thanks again.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
