Molecules/nm²? what does it mean
  • Thread starter Thread starter nadaben
    Mean
The discussion revolves around understanding the meaning of a concentration expressed in molecules per square nanometer (molecules/nm²) and how to convert this measurement into a molar or mass concentration for practical applications, particularly in the context of coating surfaces or nanoparticles.
  • Homework-related
  • One participant questions how to obtain molar or mass concentration from a measurement given in molecules/nm².
  • Another participant clarifies that molecules/nm² refers to a number of molecules per unit area, suggesting it relates to surface coating.
  • A participant expresses uncertainty about how to determine the amount needed for mixing with a solution prior to deposition.
  • It is noted that to calculate the amount needed, one must know the surface area to be covered and the volume of the solution to be used.
  • A participant inquires about calculating the quantity of a product needed to cover spherical nanoparticles, proposing to use the surface area formula (4πr²) multiplied by the given concentration.
  • Another participant confirms that the proposed approach is correct for determining the amount per nanoparticle.
Participants generally agree on the method to calculate the amount needed based on surface area, but there is uncertainty regarding the initial conversion from molecules/nm² to a usable concentration for mixing.
The discussion does not resolve the initial conversion issue, and assumptions about the surface area and volume of solution are not explicitly stated.
nadaben
Hi everyone
in an article they mentioned that the amount added of a product is given by molecules/nm²
how can i obtain a molar or mass concentration from it ?
best regards
Chemistry news on Phys.org
You can't; it is a number of molecules per unit area, not volume. Presumably to do with coating a surface or similar phenomenon. You can convert it to, say, moles/m2 if you want.
There is no way to know the amount i can take? cause i should mix it with my solution before deposition..
Do you understand how concentrations work in general?
You can calculate amount only if you know the surface which you need to cover. Then you have to decide what volume of solution to use and once you know both amount and volume you can calculate required molar concentration.
if i have spherical nanoparticles sized 30nm and i want to cover them with a product with an amount of 0.6 molecule/nm²
how can i know the corresponding quantity that i should take of this product?
is it by multipliying the surface of nanoparticle (4πr²) by 0.6?
That's amount per a single nanoparticle, but yes, that's the correct approach.
Yes exactly ! Thank u so much for your help
  • · Replies 45 ·
9K
