Moment & Distance Homework: Steel Beam & 80 kg Person
  • Thread starter Attis
  • Tags
    Moment
In summary: The center of mass of the beam-man system is not at X1/2. It is a bit closer to the man. How much closer is it?In summary, the problem involves a 10 m long steel beam (700 kg) extending 4.5 m over the edge of a roof. A person weighing 80 kg needs to be positioned on the extended part without tipping the beam over. The solution involves finding the center of mass for the beam-man system, which is not located at the middle of the beam but closer to the man.
  • #36
I think we have a terminology problem here. The limits of a range where the range is between 4.5 and 10 are 4.5 and 10.
  • #37
Does it make a difference if the range and limits are the same in this case?
  • #38
A range and its limits cannot be the same. A range is a set of numbers. A limit is a number.
Likes 1 person
  • #39
Attis said:
Morning.
Ok, so if I measure all distances from the "free end" (10 m) and let x be the point where the man is standing, then the distance of the edge of the roof from that point is (10 - x) m?
If I once again assume that the beams center of mass is situated at half of the beam, than the center of mass of the beam is 10 - 5 = 5 m
Is this correct so far? If so, can I somehow than use the formula R = 1/(m1 + m2)*∑mi*ri to find out what the distance is of the beam-man system´s center of mass from that point?? I assume that the center of mass is somewhere between 5 m and 10 m along the beam.
The center of mass of the beam-man system is going to have to be right above the fulcrum. Otherwise, the beam is going to rotate.
  • #40
Sorry if I confused anyone by my post about needing to use the moment of inertia.
We can use the centre of mass x the distance to the fulcrum to determine the net torque but it obscures the physics somewhat, which I think is the OP's problem. It may be clearer to divide the beam at the fulcrum and calculate the torques from each side. If the difference between those two torques is made up by the man, the beam is perfectly balanced (net torque = 0) and moving any farther out will tip the beam. That really was my point. Ignore that comment about the moment of inertia, which as Steamking correctly pointed out is not applicable here.
AM
Likes 1 person
  • #41
I agree with AM that the method he is describing is easier to understand and implement, even though Voko's method is correct also. I believe that the OP is studying moments in his course, so he should be using moments to solve this problem.
chet
Likes 1 person
  • #42
AM
I managed to solve the problem yesterday. My main problem was that I didn´t really get what X1 was supposed to be, so I asked my teacher. X1 was supposed to be the distance between the fulcrum and the beam´s center of mass, so if the beam has a total distance of 10 m, then the fulcrum starts at 10-4,5 m=5,5 m, and we also know that the beam´s center of mass is 5, which means that X1= 0,5 m.
I then simply used the formula m1x1=m2x2 which in this case was 700 kg* 0,5 m= 80 kg * x2 and solved for x2.
  • #43
chet
Possibly. I may have been mislead by the mention of the centre of mass/gravity in the original message.
The beam-man system is stable when its combined centre of mass is within the 4.5 - 10 m range. So we must have $$ {700 \ \text{kg} \cdot 5 \ \text{m} + 80 \ \text{kg} \cdot x \over 700 \ \text{kg} + 80 \ \text{kg}} \ge 4.5 \ \text{m} .$$
  • #44
That's what I was trying to get you to do in posts #2 and #17.
Chet
  • #45
Chet
Yes, I see that now, but I was majorly confused before. Thanks for all the help!
