Moment of Inertia - Find Area Around Y-Axis
  • Thread starter Thread starter Cheerios
    Intertia Moment
The discussion focuses on calculating the moment of inertia of a specified area about the y-axis, defined by the curve y²=2x within the bounds of 0m<x<2m and 0m<y<2m. The initial approach involved using the formula Iy= ∫x²dA, with dA chosen as xdy. After attempting the integration, the user initially arrived at an incorrect answer of 2.13m⁴ but later corrected the integration process to find the correct moment of inertia as 0.762m⁴. The thread highlights the importance of proper limits of integration and the integration process in solving such problems.
Cheerios
This is my first time posting in this site so if I left out any information or the information needs to be formatted differently I apologize ahead of time.
Determine the moment of inertia of the area about the y axis.
The curve is represented by y2=2x, and the shaded region is the smaller area above the curve.
0m<x<2m
0m<y<2m
Is the parallel axis theorem needed? If it is, why is the reason?
Since the problem asks for moment of Intertia about the y-axis
1. Iy= ∫x2dA.
2. I chose my dA to be xdy because I need to find a "bar" perpendicular to the axis I am trying to find the moment of inertia about.
3. Solved
Iy= ∫x2ydx.
I substituded (2-/sqrt(2x)) for y and solved for the integral from (0<x<2)
My answer I got was 2.13m4 and the answer is incorrect.
Is my process correct or do I need to find different limits of integration?
I don't know how to close a thread, I found out my error was in the integration process.
Solved, Iy= .762m^4.
