I "Moment of Inertia" in Virial Theorem
Moment of inertia is defined with respect to a rotational axis, calculated as I=∑miri², where ri represents the perpendicular distances from the axis. Some derivations of the virial theorem use a "scalar" moment of inertia based on the magnitudes of position vectors from the origin, which lacks the same physical significance as the traditional definition. This scalar form is not applicable to non-rigid collections of particles, as the virial theorem is typically used in such contexts. The moment of inertia tensor provides a more comprehensive understanding for rigid bodies, accommodating variations in rotation. Ultimately, discussing moment of inertia in the context of non-rigid systems is misleading.
throneoo
Moment of inertia is supposed to be defined with respect to a rotational axis such that for a system of point masses, I=∑miri2 where ri 's are the perpendicular distances of the particles from the axis.
However, in some derivations of the virial theorem (like the one on wiki), the so-called "scalar" moment of inertia, the ri 's are taken to be the magnitude of the position vectors of those particles with respect to the origin without reference to any axis. My question is, does it still have the same physical significance as its ordinary counterpart? This quantity at most indicates the overall separation of the particles from the origin
Astronomy news on Phys.org
Actually, that's not the general definition of a moment of inertia. That only applies for rigid bodies that have enough symmetry to be rotating around a fixed axis, more general rigid bodies have only a moment of inertia tensor and can have their axis of rotation wobble. Even when we choose axes that make the moment of inertia tensor diagonal, it only means that there will be different moments of inertia of the form you mention around each of those axes (and rotation around the axis with the middle-sized moment of inertia will not be stable, and will wobble). The most general definition of the moment of inertia of a rigid body can be found here: http://farside.ph.utexas.edu/teaching/336k/Newtonhtml/node64.html
The virial theorem is usually used on collections of particles that are not rigid, and the appearance of a quantity that in some superficial ways resembles a moment of inertia is just a coincidence. It's not the moment of inertia.
after readig ur link i realized talking about the moment of inertia of a non rigid collection of particles does not make much sense lol.
thanks.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
